syralk 13 Posted September 3, 2019 Posted September 3, 2019 (edited) Hi I don't know if it's because of the weird AE letter. But each time I select a letter it's always go on Aeon Flux. Edited September 3, 2019 by syralk
Solution rbjtech 5345 Posted September 3, 2019 Solution Posted September 3, 2019 yes it is exactly that and it has been discussed a few times - basically edit the metadata on Æon Flux to use AEon instead and then save and lock. 1
syralk 13 Posted September 4, 2019 Author Posted September 4, 2019 yes it is exactly that and it has been discussed a few times - basically edit the metadata on Æon Flux to use AEon instead and then save and lock. I edit the NFO and it did the trick thanks
