Luke 42244 Posted September 17, 2019 Posted September 17, 2019 I'm not convinced it's related to that. I've had gesture navigation enabled the whole time since the Android 10 update and haven't seen a crash yet.
speedingcheetah 39 Posted September 17, 2019 Posted September 17, 2019 I'm not convinced it's related to that. I've had gesture navigation enabled the whole time since the Android 10 update and haven't seen a crash yet. If that were so...then why...is that the only factor that multiple users find to be the issue on their phone?
Luke 42244 Posted September 17, 2019 Posted September 17, 2019 I appreciate that you're trying to find common factors in order to try and chase it down.
dhunterjacobs 2 Posted September 17, 2019 Author Posted September 17, 2019 I'm not convinced it's related to that. I've had gesture navigation enabled the whole time since the Android 10 update and haven't seen a crash yet. Yeah I'm not sure how one can come to that conclusion when multiple people have the issue with gestures enabled yet the issue disappears when switching to 2/3 button navigation. Seems related to gestures to me.
speedingcheetah 39 Posted September 17, 2019 Posted September 17, 2019 (edited) I appreciate that you're trying to find common factors in order to try and chase it down. Yea...i did try many things, try to narrow it down more, find something else. But I was unable. Even on clean Pixel 3 and 3a, and 3a XL, only stock apps out of the box, the app crashes with full gesture enabled, not crash with 2 button enabled. I have not had any other Android 10 phones to test on. I dont think 10 is out on any other phone models.... My guess is how the app is drawing the video to the display? maybe an MPV backend conflict? how the navigation reserve border is different with gesture on...idk.... Edited September 17, 2019 by speedingcheetah
troyhough 61 Posted September 17, 2019 Posted September 17, 2019 I'm not convinced it's related to that. I've had gesture navigation enabled the whole time since the Android 10 update and haven't seen a crash yet. Just for fun I just enabled Gesture Navigation on my Pixel 2 XL to test. I watched Live TV (HDHomerun Quatro), both Direct Play and Transcoding @ 1.5/720 on the LAN for about 5 minutes for each. Worked without issue. Tried 2-button navigation too. Also worked.
speedingcheetah 39 Posted September 17, 2019 Posted September 17, 2019 (edited) Just for fun I just enabled Gesture Navigation on my Pixel 2 XL to test. I watched Live TV (HDHomerun Quatro), both Direct Play and Transcoding @ 1.5/720 on the LAN for about 5 minutes for each. Worked without issue. Tried 2-button navigation too. Also worked. U have Quatro.....I have Prime. Which is cable card...not OTA tuner. Probably different data stream type from tuner perhaps? Mine seems to be mpeg2 or mpeg4 depending on the channel Edited September 17, 2019 by speedingcheetah
troyhough 61 Posted September 17, 2019 Posted September 17, 2019 U have Quatro.....I have Prime. Which is cable card...not OTA tuner. Probably different data stream type from tuner perhaps? Mine seems to be mpeg2 or mpeg4 depending on the channel Perhaps. Are you on Firmware: 20190621?
speedingcheetah 39 Posted September 17, 2019 Posted September 17, 2019 Perhaps. Are you on Firmware: 20190621? Same setup as https://emby.media/community/index.php?/topic/77214-android-10-live-playback/&do=findComment&comment=785227 I have Xfinity and Model: HDHR3-CC Firmware: 20190621
dhunterjacobs 2 Posted October 1, 2019 Author Posted October 1, 2019 (edited) Are you still running into this? Yes. I've attached a screenshot of the error. Again, only happens with Gesture navigation enabled. Edited October 1, 2019 by dhunterjacobs
Luke 42244 Posted October 1, 2019 Posted October 1, 2019 Ah OK, and it's System UI crashing, not our app, which is why we never get any crash reports from google. Thanks.
speedingcheetah 39 Posted October 2, 2019 Posted October 2, 2019 Ah OK, and it's System UI crashing, not our app, which is why we never get any crash reports from google. Thanks. Yes....and this fact was reported on here multiple times. But for most, it crashes so fast u cant see the crash message. just goes to lock screen.
speedingcheetah 39 Posted October 2, 2019 Posted October 2, 2019 (edited) UPDATE. My Pixel 3 just updated with a 2.4MB OS Security Update. same os build number as the sept 2109 OTA , but with a ".C3" appended onto the build number. The issue with EMBY app playing back LIVE TV is much WORSE now! Before this OS update, it would fast crash, go to lock screen, i can unlock, and then it shows the paused playback GUI screen of the live tv channel, i could otherwise back out of the app, use the app etc, even try to play again, and have it just go to lock screen. Now, it is a constant loop of crash, the second i unlock the screen, it shows the system UI crash pop up for half a second, then lock-screen again...I CAN NOT GET BACK IN TO THE PHONE>. Only a hard power off by holding the power button to kill and restart the phone will work. also, if u just leave the lock screen up, the Emby player will show is player notification thing, but the background is constantly refreshing, like the crashes are still happening in a loop in the background. I disable Gesture navigation...and Emby plays fine..... Edited October 2, 2019 by speedingcheetah
Luke 42244 Posted October 10, 2019 Posted October 10, 2019 Hi, can you please try this version and let me know how it compares: https://www.dropbox.com/s/vhejrc5j5b0h2fr/MediaBrowser.Mobile-google-armeabi-v7a-release.apk?dl=0 Thanks.
dhunterjacobs 2 Posted October 10, 2019 Author Posted October 10, 2019 Hi, can you please try this version and let me know how it compares: https://www.dropbox.com/s/vhejrc5j5b0h2fr/MediaBrowser.Mobile-google-armeabi-v7a-release.apk?dl=0 Thanks. I'm getting an error that says "Can't open file". I downloaded it to my phone and pressed the file in the download folder. I assume it should prompt me to install? I guess it isn't seeing that it's an apk.
Luke 42244 Posted October 10, 2019 Posted October 10, 2019 Yes first click that link, and then on the next page download the .apk.
dhunterjacobs 2 Posted October 10, 2019 Author Posted October 10, 2019 Yes first click that link, and then on the next page download the .apk. Ah I figured out my problem. I had to go into the files app and press the apk from there and it installed. Still have the same live playback problem with gestures enabled.
troyhough 61 Posted October 10, 2019 Posted October 10, 2019 Ah I figured out my problem. I had to go into the files app and press the apk from there and it installed. Still have the same live playback problem with gestures enabled. Did you reboot after install? Go to settings, apps, see which version you have installed...
dhunterjacobs 2 Posted October 10, 2019 Author Posted October 10, 2019 Did you reboot after install? Go to settings, apps, see which version you have installed... Just rebooted, still the same problem. I'm running version 3.0.84. I assume that's the one from Dropbox?
troyhough 61 Posted October 10, 2019 Posted October 10, 2019 Just rebooted, still the same problem. I'm running version 3.0.84. I assume that's the one from Dropbox? Thanks for confirming you tried after reboot. Is that the version you posted a link for @@Luke?
Luke 42244 Posted October 10, 2019 Posted October 10, 2019 What's your OS build number? I'm apparently on a beta build even though I don't recall signing up for that, but if my build is a little bit ahead then it could be why I've never reproduced this.
dhunterjacobs 2 Posted October 10, 2019 Author Posted October 10, 2019 What's your OS build number? I'm apparently on a beta build even though I don't recall signing up for that, but if my build is a little bit ahead then it could be why I've never reproduced this. I'm on QP1A.191005.007
