rutgerputter 0 Posted September 3, 2019 Posted September 3, 2019 Hi, I'm facing a weird issue with my xmltv guide. It doesn't display correctly on the web interface, but it works fine on Android TV. I've attached a screenshot showing this... on most channels the seems to start much later. But on the channel page, the correct programs are loaded as shown in the second screenshot. I don't think it's a server issue but I've attached the latest log and the xmltv file. Any help would be appreciated . Running latest beta 4.3.0.6 BTW. embyserver.txt guide.xml
Luke 42244 Posted September 3, 2019 Posted September 3, 2019 Hi, that is strange. I haven't seen that before. What browser and version is this?
rutgerputter 0 Posted September 3, 2019 Author Posted September 3, 2019 Hi, that is strange. I haven't seen that before. What browser and version is this? Google Chrome Version 76.0.3809.132 (Official Build) (64-bit) Also happens on Android Mobile App.
rutgerputter 0 Posted September 3, 2019 Author Posted September 3, 2019 (edited) Does that xml validate as valid xml? Just tested the file against https://codebeautify.org/xmlvalidator It says it's valid xml... strange, isn't it? But it would explain why Android TV diplays correctly. Edited September 3, 2019 by rutgerputter
Luke 42244 Posted September 3, 2019 Posted September 3, 2019 If you click on the channel and view the listings for just one channel, do they display normally?
rutgerputter 0 Posted September 3, 2019 Author Posted September 3, 2019 If you click on the channel and view the listings for just one channel, do they display normally? Yes, everything else is normal. See screenshot... all times are in order, just the guide view is off.
Luke 42244 Posted September 4, 2019 Posted September 4, 2019 Do you see this issue with the online web app? Http://app.emby.media
rutgerputter 0 Posted September 4, 2019 Author Posted September 4, 2019 Do you see this issue with the online web app? Http://app.emby.media Yes, same behaviour:
