Taiwan 0 Posted April 8, 2016 Posted April 8, 2016 Hello, I've same problem here. ANSI subtitles are not displaying correctly on Web player and over DLNA also. Using ver. 3.0.5912.0
anderbytes 141 Posted April 8, 2016 Posted April 8, 2016 English subtitles doesn't have accented chars, so it's no priority. We that are outside US have to keep bugging the devs so they can understand how important this is for us. 1
Koleckai Silvestri 1154 Posted April 8, 2016 Posted April 8, 2016 The image above wouldn't be ANSI... The Question mark symbol is used by web browsers when they encounter an unknown symbol. That means the character is outside the character set they are told to work with. In this case, it is most likely a UTF-8 character outside the 256 character spectrum of ANSI. What you really need to ask for is better UTF-8 support on the subtitles. This could be converting it to the ANSI equivalent if possible or an entity character sequence (for HTML-based apps). Though, full UTF-8 support would be more beneficial over time.
Luke 42217 Posted April 8, 2016 Posted April 8, 2016 Hello, I've same problem here. ANSI subtitles are not displaying correctly on Web player and over DLNA also. Using ver. 3.0.5912.0 Please provide a sample file.
rbanaco 2 Posted September 13, 2016 Posted September 13, 2016 Same problem here... can't you make a default enconding like some software to UTF-8? I won't be changing the enconding manually for each srt file I have, neither the name to *.por.srt for every single one. Portuguese sub are *.pt.srt and brazilian as *.por.srt Kodi treats the subtitles as they should automatically..
anderbytes 141 Posted September 13, 2016 Posted September 13, 2016 Actually portuguese for Brazil is pt-BR or pob
rbanaco 2 Posted September 13, 2016 Posted September 13, 2016 (edited) Yes, sorry! portuguese is pt or pt-pt any development on this matter? Edited September 13, 2016 by rbanaco
Luke 42217 Posted September 13, 2016 Posted September 13, 2016 Yes, sorry! portuguese is pt or pt-pt any development on this matter? Hi, can you please describe your issue? Thanks !
rbanaco 2 Posted September 14, 2016 Posted September 14, 2016 (edited) Hello, The issue is when I put to play a file with subtitles (external in srt) it doesn't show the characters like "ã, é, à"... etc.. Kodi has no problem playing them. If I change in notepad++ the encoding to UTF-8 it plays nice, the problem is that I will not do that to every single file in my library because it defeats the purpose of the media player with no hassles. Can't you implement an auto recognition? or manual, like selecting the UTF-8 in the options menu for character encoding? Renaming subs or changing the encoding in Notepad++ is not a hassle free option. Thank you. Edited September 14, 2016 by rbanaco 1
anderbytes 141 Posted September 14, 2016 Posted September 14, 2016 Hello, The issue is when I put to play a file with subtitles (external in srt) it doesn't show the characters like "ã, é, à"... etc.. Kodi has no problem playing them. If I change in notepad++ the encoding to UTF-8 it plays nice, the problem is that I will not do that to every single file in my library because it defeats the purpose of the media player with no hassles. Can't you implement an auto recognition? or manual, like selecting the UTF-8 in the options menu for character encoding? Renaming subs or changing the encoding in Notepad++ is not a hassle free option. Thank you. AFAIK, @@Luke is working on it --> http://emby.media/community/index.php?/topic/23624-subtitle-problem-for-accented-characters/page-4
rbanaco 2 Posted September 14, 2016 Posted September 14, 2016 Ah, I didn't know if he is, let's wait for it! thanks! Any questions or tests I'm available.
anderbytes 141 Posted September 14, 2016 Posted September 14, 2016 What OS are you running on? If the question was for me --> Running Emby Official Docker image in Docker in a Debian 7 Host (O.M.V. v2 NAS)
rbanaco 2 Posted September 14, 2016 Posted September 14, 2016 If it was for me, emby is running in a jail of Freenas 9.10.1 .
anderbytes 141 Posted September 14, 2016 Posted September 14, 2016 If it was for me, emby is running in a jail of Freenas 9.10.1 . You forgot to say that FreeNAS 9 runs under FreeBSD 9.
rbanaco 2 Posted September 14, 2016 Posted September 14, 2016 You forgot to say that FreeNAS 9 runs under FreeBSD 9. True... thanks. I thought saying FreeNAS would be self explanatory.
djhifi 56 Posted September 15, 2016 Posted September 15, 2016 (edited) Altough I rarely stream content I would like to know why this also happens to me? I mean, Im portuguese, ANSI subs and yes, streaming places "?" on special characters like OP. If I change the sub encode to UTF-8 all this goes away. But im not interested for several reasons. Even more funny, as you can check here: http://emby.media/community/index.php?/topic/39130-playback-subtitles-weird-display/?p=366770 other people even tested the subs I sent and reported back no problems whatsoever The EMBY server is installed on a synology 1813+ machine. Even from my windows PC streaming via server the same error occurs.... Edited September 15, 2016 by djhifi
archonus 4 Posted October 3, 2016 Posted October 3, 2016 i have same issue with spanish subtitles using Debian linux
djhifi 56 Posted November 8, 2016 Posted November 8, 2016 i have same issue with spanish subtitles using Debian linux @@archonus It's not solved for MONTHS. https://emby.media/community/index.php?/topic/39560-subtitle-ansi-marking-on-accented-characters/ Check above.
anderbytes 141 Posted November 8, 2016 Posted November 8, 2016 I have already given server logs, client logs, screenshots, SRT samples... I don't know what else to do. See the difference: - Live TV - usually for American users that receive TV via cable -> gets a lot of attention, fixes and updates - Subtitles - for non-English users -> sometimes gets attention, fixes and updates I can't explain myself better than that. I've already gave up submitting issues related to Subtitles downloaded via Emby. I just ignore that Emby can do that, and use Subliminal to download them myself. Not even my suggestion of Emby using Subliminal was heard in the past.
Luke 42217 Posted February 22, 2019 Posted February 22, 2019 Addic7ed is now in the Emby plugin catalog. You'll need to configure your Addic7ed credentials in the plugin configuration. Enjoy.
