martinix 2 Posted November 18, 2019 Author Posted November 18, 2019 The problem occurs with Emby for Kodi (4.1.15) . EmbyCon seems to work ok. The developer, Angelblue05, noted the likely cause of the problem (see above) but it seems uncertain whether a fix is possible or not.
Angelblue05 4132 Posted November 18, 2019 Posted November 18, 2019 (edited) You always have the option to not sync your music library. Then it should work the same as embycon. Thanks for letting me know this is not resolved with 4.1.15. I don't see this myself nor does @@sualfred. Can you provide an updated Kodi log? Enable Kodi debug. Take note the time the skip happens. Edited November 18, 2019 by Angelblue05
martinix 2 Posted November 20, 2019 Author Posted November 20, 2019 sorry for my delayed response. I checked again and everything seems ok now. I reset and re-synced the library and that seemed to fix the problem. I'm not getting any skips now. You always have the option to not sync your music library. Then it should work the same as embycon. Thanks for letting me know this is not resolved with 4.1.15. I don't see this myself nor does @@sualfred. Can you provide an updated Kodi log? Enable Kodi debug. Take note the time the skip happens. thanks for your help.
Saviq 22 Posted November 20, 2019 Posted November 20, 2019 Thanks for letting me know this is not resolved with 4.1.15. I don't see this myself nor does @@sualfred. Can you provide an updated Kodi log? Enable Kodi debug. Take note the time the skip happens. Hey @@Angelblue05, Does it have to be a transcoding stream, though? Could the plugin not just feed the file as-is? This way the ranged request would work according to Luke a couple replies above?
Angelblue05 4132 Posted November 21, 2019 Posted November 21, 2019 (edited) @@Saviq Can you test this build for me? First install it and try to see if it still cuts at the end. I added static=true to the redirect for music. If this works, let me know. Otherwise second step, in the add-on settings > advanced > enable developer mode > Save. Restart Kodi, you should see a new patch applied. Resync your music library. Then try to play and let me know if it cuts short still. I have removed the file extension so that it reflects as Luke posted above. Thanks. plugin.video.emby-4.1.16a.zip Edited November 21, 2019 by Angelblue05
Saviq 22 Posted November 22, 2019 Posted November 22, 2019 Hey @@Angelblue05, Yes that seems to fix the issue for me, I've been playing random music most of the day and no cut offs. That said, is that the correct fix? What if the file is in a format that Kodi doesn't support? 1
Angelblue05 4132 Posted November 23, 2019 Posted November 23, 2019 (edited) Did you try it in two steps like I asked? At which point did it work correctly, just with the build given or with developer mode enabled/kodi restarted? Yeah if the format is not supported... Edited November 23, 2019 by Angelblue05
Saviq 22 Posted November 23, 2019 Posted November 23, 2019 I just installed the plugin and started playing, didn't notice an interrupt since. 1
