m3shserver 0 Posted August 31, 2019 Posted August 31, 2019 On the home dashboard under Live TV it shows "On Now" but it seems to show double entries for each channel, there are no double entries of the channels in the TV Guide.
Luke 42217 Posted August 31, 2019 Posted August 31, 2019 Hi there can you please go over an example? Can you show a screenshot? Have you tried refreshing the guide data in server settings?
m3shserver 0 Posted August 31, 2019 Author Posted August 31, 2019 Sorry I thought I had attached a screen shot, have done again. Refreshing guide data has no effect.
m3shserver 0 Posted August 31, 2019 Author Posted August 31, 2019 Sorry I thought I had attached a screen shot, have done again. Refreshing guide data has no effect. Ah think I have found out why, SD and HD channels.....
Luke 42217 Posted September 1, 2019 Posted September 1, 2019 Ok, we plan to expand our channel management features in the future to allow you to remove the SD channels. For now there are other ways you could remove them, such as checking the option to only import your favorite HDHR channels, and then using the HDHR web interface to mark your favorite channels.
m3shserver 0 Posted September 1, 2019 Author Posted September 1, 2019 OK, will give that a try. Thanks
