PenkethBoy 2068 Posted September 13, 2020 Author Posted September 13, 2020 Just now, Luke said: Did you try running them through ffprobe to see if the artists are recognized consistently between the two? No - but see above i think its a db issue as with a new db it works The db is not that old a few months and my test server - which i mess with so might be related although i have not done anything on MV for a while
PenkethBoy 2068 Posted September 13, 2020 Author Posted September 13, 2020 Adding the plugin back in appears to have worked fine also - from a quick check
PenkethBoy 2068 Posted September 13, 2020 Author Posted September 13, 2020 @Luke Had a very quick look at the old db vs the new one and cant see anything obvious thats different for MV's Can send you a copy if that would be useful?
PenkethBoy 2068 Posted September 13, 2020 Author Posted September 13, 2020 ok will PM you a copy to see if you can spot something
