guillito 0 Posted June 2, 2014 Posted June 2, 2014 Hello everyone. Sorry for my poor English . I am having problems since the last update ( 3.0.5264.17006 ) , before that everything worked brilliantly well .PCs with MBC show info of the movies , but play him , reports that : My configuration was always put in the library , the local Original location of the folder with movies and use path sustitution : Always worked well as I said, until the last upgrade .I will say , why not add directly and not use UNC Paths sustitution path ?If I do this , I miss being able to change from the same MBS entire metadata of movies and series, because as a network path , to change something, I am informed that you can not save .Things I've tried?- In another PC , put together a new collection , which is to rule my server. Also feel the same, get the same error. - Renaming foldes, not work.- Try putting the IP address in number , not name server. Same error.- As I said , try using UNC Paths in the library , and WORK, as before the movies are played on all PCs with MBC , but when I want to edit metadata MBS and not allow it to be network drives, not local .Some happened the same? Any possible help ?Greetings from Argentina and thank you very much for your help and read me.
ebr 16306 Posted June 2, 2014 Posted June 2, 2014 This is a bug in the Beta server. Go back to the official release until it can get squashed. 1
guillito 0 Posted June 2, 2014 Author Posted June 2, 2014 This is a bug in the Beta server. Go back to the official release until it can get squashed. Thank you very much for your answer! Considers that it was not doing anything wrong and had everything configured correctly. Ask, as I do to make a downgrade of MBS, ie back to a previous version? Regards and thanks again.
Solution ebr 16306 Posted June 2, 2014 Solution Posted June 2, 2014 Just re-install the server from the web site and pick the "Released" version. 1
guillito 0 Posted June 2, 2014 Author Posted June 2, 2014 Just re-install the server from the web site and pick the "Released" version. Thank you very much for your answer! Again! Work fine! Regards
