biour 1 Posted September 11, 2019 Author Posted September 11, 2019 If you'd like to try beta server 4.3.0.8 that would be helpful. @@softworkz will be looking at this. Thanks. Ok i will try 4.3.0.8 when available
biour 1 Posted September 11, 2019 Author Posted September 11, 2019 installed 4.3.0.8 make a fast test on the 1gb test file and the 10gb one with Chrome. stil no sound (except on android app as usual)
Solution Luke 42246 Posted September 11, 2019 Solution Posted September 11, 2019 One thing you could check in the mkv file is if the second audio track has a large audio delay set in it's metadata. If it does, then currently with transcoding this is a known issue. 1
biour 1 Posted September 11, 2019 Author Posted September 11, 2019 (edited) it seems you're right ! 9.9s for the 1gb file, 19s for the 10gb Edited September 11, 2019 by biour
