biour 1 Posted August 29, 2019 Posted August 29, 2019 Hello, I've a trouble since the last version i presume. I was unable to have sound on the second audio track for lots of Video (mainly AC3 so far). Tested on Chrome/Firefox/Edge/Emby theater windows (all up to date) and many other pc. Only the android app work fine (I've an xbox one S but not tested so far). The movie seems to start normaly but no sound (with the second audio track, with the first no problem). Server: Unbuntu 18.04 up to date. Please found log file included (server and ffmpeg remux) Best regards, Biour embyserver (1).txt ffmpeg-remux-04d4574d-d75b-40a1-a459-075a2679d064_1.txt ffmpeg-remux-ec552118-347a-4e4e-9491-e6f3813a38cb_1.txt ffmpeg-remux-b85cfece-6452-4d8c-9ae2-fa72ac93290c_1.txt ffmpeg-remux-915e7d3b-776d-4a7c-97e9-144b2642cc35_1.txt ffmpeg-remux-1ec5ef8e-ef4b-46c9-a3c3-04dc422881b1_1.txt ffmpeg-remux-34a7d8ce-0764-435c-a914-c5b8d61675bc_1.txt
biour 1 Posted August 29, 2019 Author Posted August 29, 2019 (edited) try to downgrade to emby-server-deb_4.2.1.0_amd64.deb --> Same trouble emby-server-deb_4.1.1.0_amd64.deb --> Same trouble emby-server-deb_4.0.0.2_amd64.deb --> Same trouble (beta) emby-server-deb_4.3.0.6_amd64.deb --> Same trouble Edited August 29, 2019 by biour
Luke 42246 Posted August 30, 2019 Posted August 30, 2019 Hi there, this is an interesting video with the video stream being last in the container. Can you provide a copy of it for testing? Thanks.
biour 1 Posted August 30, 2019 Author Posted August 30, 2019 it's a 10gb one. https://uptobox.com/mktdrahozucl (need pay account) or multi volume archive https://uptobox.com/q5ec37bnndx6 https://uptobox.com/hot34ofo81sj https://uptobox.com/nyr7o12sgzex https://uptobox.com/jian1vpvw3mw https://uptobox.com/jone45cua8gq https://uptobox.com/v75hkv1jc3o7 https://uptobox.com/39x8zjrstp8g https://uptobox.com/jrek50nlmi24 https://uptobox.com/li4568vg9bl5 https://uptobox.com/6mglh9idqc7d https://uptobox.com/6eezv7tpwg9z
biour 1 Posted August 30, 2019 Author Posted August 30, 2019 if it doesn't work maybe i can provide the download link from my emby?
Luke 42246 Posted August 31, 2019 Posted August 31, 2019 10gb is a bit much. Is it possible to create a 1 minute slice using mkvmerge?
biour 1 Posted August 31, 2019 Author Posted August 31, 2019 10gb is a bit much. Is it possible to create a 1 minute slice using mkvmerge? i will try tomorow.
biour 1 Posted September 2, 2019 Author Posted September 2, 2019 Please find the approx 1min slice attached (zipped to bypass the mkv restriction). (sorry for the delay) John.Wick.Parabellum.-slice.zip
Luke 42246 Posted September 3, 2019 Posted September 3, 2019 Can you test the sample file and let me know if you get audio with that on the second track? Because it seems to be working fine for me. Thanks.
biour 1 Posted September 3, 2019 Author Posted September 3, 2019 (edited) The slice works fine. :/ maybe i may create an account on my server? send me a PM if ok Edited September 3, 2019 by biour
biour 1 Posted September 3, 2019 Author Posted September 3, 2019 So what i noticed, it works with android not working when it use Html-player or windows video player
Luke 42246 Posted September 3, 2019 Posted September 3, 2019 @@softworkz do you think your audio change might impact this?
softworkz 5133 Posted September 3, 2019 Posted September 3, 2019 @@softworkz do you think your audio change might impact this? No it won't. Actually that wasn't about audio at all. It was a fix for writing mkv (and other container-) headers. It just happened to be an audio track showing incorrect metadata that brought this to our attention.
Luke 42246 Posted September 3, 2019 Posted September 3, 2019 @@biour as a test, if you lower the in-app quality setting to force a full video transcode, does that make a difference?
biour 1 Posted September 3, 2019 Author Posted September 3, 2019 @@biour as a test, if you lower the in-app quality setting to force a full video transcode, does that make a difference? no change (forced to 480p 1mbps)
biour 1 Posted September 3, 2019 Author Posted September 3, 2019 i've exported some date from the file with mediainfo one working the other not if it may help notworking.txt working.txt
biour 1 Posted September 4, 2019 Author Posted September 4, 2019 I've tested on the Xbox one app, same (no sound on the french track)
Luke 42246 Posted September 4, 2019 Posted September 4, 2019 Do you have any smaller files that this happens with?
biour 1 Posted September 4, 2019 Author Posted September 4, 2019 If ok this one have the same trouble http://dl.free.fr/bQtY0rk5p no audio on the second track (french)
Luke 42246 Posted September 5, 2019 Posted September 5, 2019 Thanks. I've downloaded it but I'd like @@softworkz to download as well. 1
biour 1 Posted September 6, 2019 Author Posted September 6, 2019 Thanks. I've downloaded it but I'd like @@softworkz to download as well.did you face the same issue ?
biour 1 Posted September 11, 2019 Author Posted September 11, 2019 May help on anything? Some info about the problem? Best regards.
Luke 42246 Posted September 11, 2019 Posted September 11, 2019 If you'd like to try beta server 4.3.0.8 that would be helpful. @@softworkz will be looking at this. Thanks.
