the1legend 45 Posted September 21, 2019 Posted September 21, 2019 No such luck for me. My Home app appears current, V2.14.1.11 (Latest update to the app was five hours ago). My wife's Home app is on the same version, she also cannot Cast. I also have a iPad with the Home app, it also will not Cast to the same devices listed in my previous post.
jamvids 39 Posted September 21, 2019 Posted September 21, 2019 Also can confirm no luck, other apps are working fine. Sent from my J8110 using Tapatalk 1
mikeraburn 71 Posted September 21, 2019 Posted September 21, 2019 Maybe it is was an USA only thing but they usually do us and UK together. I read about it first on Android Central and then got the update. My version is the same as the1legend mentions. I cast my android PHONE to a Google Home Mini speaker or speaker group then launch Emby on my android device and away it goes. CASTING from within the Emby android app does not work. It is as the1legend describes. 1
moviepalace4K 30 Posted September 22, 2019 Author Posted September 22, 2019 Here in Belgium, it still doesn't want to cast to the Google Home Mini's.
artatgray 8 Posted September 27, 2019 Posted September 27, 2019 (edited) Yes, I've had the problem of not being able to cast to a CCA with the latest update as well. I've two different Android devices I'm using and neither can cast. I'd done reboots and complete resets to no avail. Edited September 27, 2019 by artatgray
Luke 42244 Posted September 27, 2019 Posted September 27, 2019 Ok please give it another try. Thanks. 2
jamvids 39 Posted September 27, 2019 Posted September 27, 2019 That's the one. Working again cheers. Sent from my J8110 using Tapatalk
moviepalace4K 30 Posted September 27, 2019 Author Posted September 27, 2019 OK !!!!! Here it also works back !!!!! THANK YOU !!!!
