chowbok 136 Posted August 28, 2019 Posted August 28, 2019 On my Fire stick "repeat" doesn't seem to work. I can select it fine, it just doesn't in fact repeat. I imagine this hasn't come up too much because not too many people will be watching movies or TV shows on repeat, but I just added some video fireplaces and aquariums and suchlike and I like to leave them running in the background.
Kramerika 18 Posted August 28, 2019 Posted August 28, 2019 I didn't know this option (video repeat) was added for the Fire TV/Android TV. I'll have to check when I get home to see if it is there/works on both as I have both Fire TV boxes and Nvidia Shield boxes. I have been wanting it for a while for the same reason, repeating background video like a fireplace or aquarium. https://emby.media/community/index.php?/topic/48244-32198-repeat-mode/
ebr 16338 Posted August 28, 2019 Posted August 28, 2019 How many items were in the playback queue? I think there may be a bug where it only works if there are multiple items. Actually strike that...
Kramerika 18 Posted August 30, 2019 Posted August 30, 2019 Confirmed that this does not work. I want to repeat play the item that is playing. I tried to use the Repeat setting while playing it. I set it to One and then to All. That did not work. I tried adding it to the queue and then doing the same. That did not work either. What sequence of settings would I use to repeat play one video?
ebr 16338 Posted August 30, 2019 Posted August 30, 2019 Yes, there is an issue. It will be fixed in the next beta. Thanks.
