jhs39 13 Posted June 2, 2014 Posted June 2, 2014 (edited) Media Browser++ will not open on my Roku 3 since the latest server update. The splash screen comes on but that's it. The standard Media Browser chanel still opens fine but I prefer the user interface on the version I paid for. Any idea what is going on with this? I also added Media Browser++ lite which worked fine. When I upgraded to the full version the same thing happened--the channel never opened past the splash screen. Edited June 2, 2014 by jhs39
jhs39 13 Posted June 2, 2014 Author Posted June 2, 2014 I got it to work. The modern theme that I was using seems to be causing a problem. I was able to uninstall Media Browser++, reboot the Roku, install Media Browser++ Lite and then update to Media Browser++. It had me set up my server and opened fine. When I was putting in my settings Media Browser++ crashed as soon as I changed the theme to modern. I came out of Media Browser++ and went back in and I had the exact same problem with the splash screen freezing. So I went through the entire process again, got a working version of Media Browser++ on my Roku and changed all of my settings but left the theme at the default--now it's working fine. 1
im85288 1493 Posted June 3, 2014 Posted June 3, 2014 Thanks for the info, this should hopefully be fixed properly in the next version
neovisual 0 Posted June 16, 2014 Posted June 16, 2014 (edited) For me this happens when I change the "Movies" row from "Resume" to "Latest" regardless of theme choice. I can change it in the Light version without issue though. I think I'll just stick with Light anywhow, it's a lot less busy than the full. Edited June 16, 2014 by neovisual
im85288 1493 Posted June 16, 2014 Posted June 16, 2014 Thanks for the info, I will try and reproduce this as it is happening for a few people now.
cabuckley88 1 Posted October 28, 2015 Posted October 28, 2015 On 2.19 MB Media Centre, themes still brick the app requiring reinstall and reboot. Not sure why. Just an update.
