Bazzu85 22 Posted August 27, 2019 Posted August 27, 2019 Hi, then new downloaded media management is awesome.. but...I found a problem I have a show with the last two unwatched episode in sync.. watching the 2 episode synced the server makes the sync to queue the 2 next items.. the problem is this: I'm on mobile network and the sync starts only on wifi..but now I see the new episode with the downloaded/original version choose.. If I choose to play the default downloaded version, nothing happens (because of the missing offline files) the downloaded version as to appear when the file is actually on device.. thx
Luke 42245 Posted August 27, 2019 Posted August 27, 2019 Hi, so you're saying it's available to play before it's actually finished downloading?
Bazzu85 22 Posted August 27, 2019 Author Posted August 27, 2019 Hi, so you're saying it's available to play before it's actually finished downloading? I'm saying that I see the choose of play downloaded media or server version even if the download isn't started..
Luke 42245 Posted August 27, 2019 Posted August 27, 2019 Got it, thanks for reporting. We'll take a look at this.
