gillmacca 17 Posted August 26, 2019 Posted August 26, 2019 All my tv shows and movies were marked on the trakt site as collected, but have noticed today that nothing is now marked as collected. Not sure if it is the trakt plugin, a setting in the plugin or an issue on the trakt website. Can someone check to see if their content on the trakt site is marked as collected? Many thanks
Luke 42255 Posted August 27, 2019 Posted August 27, 2019 Hi there, have you tried running the trakt scheduled tasks?
Luke 42255 Posted August 28, 2019 Posted August 28, 2019 What exactly did you do? How have you configured the trakt plugin?
Solution gillmacca 17 Posted August 28, 2019 Author Solution Posted August 28, 2019 Have to apologise, just found my mistake.Under exclude folders, I had selected movies & TV, rather than the other folders 1
