mcalbert007 2 Posted August 26, 2019 Posted August 26, 2019 hey all, I need some help with the metadata area of emby. I have a couple of 8tb external hdd's. The problem i'm having is all my emby stuff is on 1 drive K:\\ but i get metadata media being saved to another drive G:\\ Is there any way to stop this from happening. thanks for any help with this.
darkassassin07 672 Posted August 26, 2019 Posted August 26, 2019 Server Dashboard > Library (on the left bar) > Advanced You have the option to set the medatada folder. You also have the option within each libraries individual settings to save artwork alongside the media itself. 1
mcalbert007 2 Posted August 26, 2019 Author Posted August 26, 2019 thanks for the reply yep I have this set to K drive but I still get stuff showing up in G drive in the same folder location just on wrong drive I don't like the artwork in beside the media, I tried that in the beginning but it just makes a large mess
