the1legend 45 Posted August 25, 2019 Posted August 25, 2019 I bounce back and forth between Plex and Emby on the Shield. I never noticed until now that Emby does not have the option to list genres in the movie section. Any chance that option will be added soon? Thanks!
ebr 16338 Posted August 25, 2019 Posted August 25, 2019 Hi. Yes, there is a Genres tab in any movie library. Where are you looking? 1
the1legend 45 Posted August 25, 2019 Author Posted August 25, 2019 Oh? I just go to my movie library. Is it somewhere else?
Solution the1legend 45 Posted August 25, 2019 Author Solution Posted August 25, 2019 (edited) After you said this I started looking at my settings. In display preferences, I had Simple Grid View selected, not Tab View. Apparently in the Simple Grid View you can not see the sorting options. I should have asked about this a month ago, such a simple fix! Thanks @@ebr Edited August 25, 2019 by the1legend 1
ebr 16338 Posted August 26, 2019 Posted August 26, 2019 Yes, correct. A simple grid gives you just that. You must've changed this option at some point because the default is the tabbed view. Thanks for reporting back.
