BillOatman 597 Posted August 25, 2019 Posted August 25, 2019 (edited) Hi, I have a guide logo defined in my meu/xmltv files that Emby will not display, but every other image viewer I've tried does. The logo is at http://www.stickpng.com/assets/thumbs/584d4a490a44bd1070d5d484.png Emby displays nothing, with the web player or android TV. In the web player, when I right click and tell it to display the image in another tab, it shows Unable to determine image file extension from mime type text/plain My image viewer says it's compression is PNG - ZIP, not sure if that is confusing Emby or not. Edited August 25, 2019 by BillOatman
BillOatman 597 Posted August 25, 2019 Author Posted August 25, 2019 (edited) @Luke Emby displays nothing (it's channel 161). The channel plays fine. Edited August 26, 2019 by BillOatman
Happy2Play 9806 Posted August 25, 2019 Posted August 25, 2019 (edited) Is this not the same issue as this topic? Issue with the way Emby is parsing the EPG img src. https://emby.media/community/index.php?/topic/76554-emby-log-errors-how-to-troubleshoot/?p=776728 Edited August 25, 2019 by Happy2Play
BillOatman 597 Posted August 25, 2019 Author Posted August 25, 2019 Similar it seems. Different error but maybe the same root cause.
BillOatman 597 Posted August 25, 2019 Author Posted August 25, 2019 FWIW, someone tried that link in Plex and it worked.
BillOatman 597 Posted August 27, 2019 Author Posted August 27, 2019 I took a look at the jellyfin code and ran that path in my first post through it's mime code figuring maybe this part hadn't changed much. It identified the mime type correctly as ""image/png"".
Luke 42218 Posted August 27, 2019 Posted August 27, 2019 Sorry what exactly is the problem? Can you attach a server log? thanks.
BillOatman 597 Posted August 27, 2019 Author Posted August 27, 2019 The problem is in the first post. I'll get a server log tonight.
Solution Happy2Play 9806 Posted August 27, 2019 Solution Posted August 27, 2019 (edited) If it is the same issue as the linked topic then it is potentially fixed in beta 4.3.0.6. But server logs should provide more information. Edited August 27, 2019 by Happy2Play 1
BillOatman 597 Posted August 28, 2019 Author Posted August 28, 2019 I had already switched logos. I'll wait for the next release and try it then. Sounds like it could well be the same problem. Thanks.
