Maisy 37 Posted June 4, 2021 Posted June 4, 2021 It works great! Lovely on my 4K 49" desktop in desktop mode full screen or smaller windowed. Next I'll have to try it on my 13" doesn't scale in-betweener. The only thing that is still a problem in this build is how it won't maximize truly, it is draggable still. This scaling though is superb! 1
Maisy 37 Posted June 16, 2021 Posted June 16, 2021 I'm still using the fixed ET for windows scaling, just wanted to show the 1 main visual problem: Words cut off on Edit images screen.
Luke 42239 Posted June 16, 2021 Posted June 16, 2021 5 hours ago, Maisy said: I'm still using the fixed ET for windows scaling, just wanted to show the 1 main visual problem: Words cut off on Edit images screen. Thanks for reporting. We'll take a look.
moonman 7 Posted August 22, 2021 Author Posted August 22, 2021 The test version works great in terms of scaling, thank you. However in the test version downloaded from dropbox subtitles are now shown even though they are turned off in the CC menu. I have to go it to CC, enable anysubtitles, then turn them off, then they disappear.
Luke 42239 Posted August 22, 2021 Posted August 22, 2021 16 hours ago, moonman said: The test version works great in terms of scaling, thank you. However in the test version downloaded from dropbox subtitles are now shown even though they are turned off in the CC menu. I have to go it to CC, enable anysubtitles, then turn them off, then they disappear. Strange. I don't see that in my testing.
moonman 7 Posted September 5, 2021 Author Posted September 5, 2021 On 8/22/2021 at 12:58 PM, Luke said: Strange. I don't see that in my testing. Sorry it took me a while to get back here. I've tried several different video files, and it does not happen with all of them. But this is one of the files that it happens with: https://we.tl/t-DJxDRMn2Q3
Luke 42239 Posted September 6, 2021 Posted September 6, 2021 20 hours ago, moonman said: Sorry it took me a while to get back here. I've tried several different video files, and it does not happen with all of them. But this is one of the files that it happens with: https://we.tl/t-DJxDRMn2Q3 @generiq are you able to reproduce?
Guest Posted September 6, 2021 Posted September 6, 2021 29 minutes ago, Luke said: @generiq are you able to reproduce? Yes, but only with the libmpv renderer. Using the GPU renderer, it's fine. Something to add though, this is only with the test build and not with the current release.
moonman 7 Posted September 6, 2021 Author Posted September 6, 2021 (edited) 5 hours ago, generiq said: Yes, but only with the libmpv renderer. Using the GPU renderer, it's fine. Something to add though, this is only with the test build and not with the current release. Are you referring to "Video output" setting under Settings -> Video? I tried both and same issue happens on both. It was initially set to auto. Yes , it only happens with the test build. Edited September 6, 2021 by moonman
Guest Posted September 6, 2021 Posted September 6, 2021 @Lukehas the release got the text scaling update?
Luke 42239 Posted September 6, 2021 Posted September 6, 2021 37 minutes ago, generiq said: @Lukehas the release got the text scaling update? Not the latest release on the website.
Guest Posted September 6, 2021 Posted September 6, 2021 Ah, I thought it had by now. That's why I made that comparison.
Luke 42239 Posted September 6, 2021 Posted September 6, 2021 We'll need to look at fixing this subtitle issue and then we can get a release out. 1
Guest Posted September 6, 2021 Posted September 6, 2021 An update, @moonmanis correct. When I first tested, with GPU I didn't have subs, but testing again, I can reproduce what he's said. The subs are initially activated with both renderers, and you have to cycle through then to disable them.
Guest Posted September 6, 2021 Posted September 6, 2021 (edited) Ok, I think I figured this out. In the file headers, the subtitle track is marked as default...by default... Confusing? The track had no default header, so it defaults to yes. Adding the header and setting it no, the issue is no longer reproduced. Like this; No header With header With no header, this is what happens Edited September 6, 2021 by generiq
Guest Posted September 6, 2021 Posted September 6, 2021 So Theater is just obeying the default, and ignoring the UI settings
Luke 42239 Posted September 7, 2021 Posted September 7, 2021 2 hours ago, generiq said: So Theater is just obeying the default, and ignoring the UI settings Yes it looks that way. Thanks.
moonman 7 Posted September 10, 2021 Author Posted September 10, 2021 (edited) Great! subtitles bug has been fixed. Thank you sir. One minor issue, which is not a big deal, but I thought I would mention it anyway. In "stats for nerds" Display Fullscreen Resolution appears to be off. It does not look like it's that low of a resolution, nevertheless here is what it's showing on a 4k screen. My guess it's due to the introduction of scaling. Like I said it does not affect the functionality in any way. Edited September 10, 2021 by moonman
Luke 42239 Posted September 10, 2021 Posted September 10, 2021 Ok yea I don't think that information is needed anyway. Thanks.
Guest Posted September 10, 2021 Posted September 10, 2021 That's old. It's been updated to provide what the actual scale is. @Luke don't remove it, just update mpv.
Guest Posted September 10, 2021 Posted September 10, 2021 Here's the commit https://github.com/mpv-player/mpv/commit/76a53f9de3592c435def1d020fab4a05f88a14e0
Luke 42239 Posted September 10, 2021 Posted September 10, 2021 10 hours ago, generiq said: That's old. It's been updated to provide what the actual scale is. @Luke don't remove it, just update mpv. Yea but even still, I'm not sure it's really necessary to remind you what your own desktop resolution is. As it is having to scroll due to so much info, it's not great, so anything that's not important that can be cut will help reduce that.
