Napsterbater 26 Posted August 24, 2019 Posted August 24, 2019 Seems Stats for Nerds is reporting Megabits per second as MB/s (i.e. Megabytes per second), it should be Mb/s (i.e. Megabits per second).
speechles 2062 Posted August 24, 2019 Posted August 24, 2019 (edited) Yeah.. I did that wrong to begin with and was afraid to make changes "just to change that back" since it was so minor. @@ebr if you want to just make that switch by hand it is in the bitratedisplay within the video player where it adds that. I notice too "XXMB/s" vs "XX KB/s". I spaced out the numbers from the KB but did not do the same on the MB. Once that bitrate display was built I forgot to ever go back and after so long you notice it is there but until someone else says FIX IT you just leave it alone. In this case here comes the FIX IT finally. I am glad someone felt bold enough to finally mention this. Thank you @@Napsterbater Edited August 24, 2019 by speechles
