nanuk 36 Posted August 23, 2019 Posted August 23, 2019 Hi Pünktchen, actually it is not possible to do any changes to the MediaPortal Plugin settings. The settings are shown normally and I can do any changes I like to, but when pressing the "save" button nothing happens. Seems to be a prob of the mediaportal plugin because changing the settings of other plugins works well. After pressing "Save" I get an response like "settings saved". In mediaportal plugin nothing is happening after pressing the save button. can you reproduce this behavior? Thanx and greetz nanuk
nanuk 36 Posted August 23, 2019 Author Posted August 23, 2019 Hi, Server Version: 4.2.1.0 Plugin Version: 1.9.3.0
Luke 42237 Posted August 23, 2019 Posted August 23, 2019 Can you please capture the contents of the browser debug console? thanks.
pünktchen 1410 Posted August 24, 2019 Posted August 24, 2019 Can you please capture the contents of the browser debug console? thanks. Here you go:
Solution nanuk 36 Posted August 25, 2019 Author Solution Posted August 25, 2019 Hi Luke, hi pünktchen, with mediaportal plugin 1.9.4 saving of settings now works again ;-) thanx
