MoonPie2000 0 Posted August 22, 2019 Posted August 22, 2019 Several seconds after enabling live seeking (scenario 1) or tuning a channel (scenario 2) an audio drop happens followed by random audio drops / video stuttering. Scenario 1: Enable Direct stream live TV from Live TV settings menu and Enable live seeking when viewing channel Scenario 2: Disable Direct stream live TV from Live TV settings menu
Luke 42246 Posted August 22, 2019 Posted August 22, 2019 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
ebr 16338 Posted August 22, 2019 Posted August 22, 2019 Logs will probably tell the tale but my guess is your server is struggling with the transcoding.
MoonPie2000 0 Posted August 25, 2019 Author Posted August 25, 2019 I have done several days of testing with different clients (Plex, Emby) and different Emby versions on two different Android TV end points (Shield, Mecool). Server Hardware/Software OS Version:FreeNAS-11.2-U5 (Build Date: Jun 24, 2019 18:41) Processor:Intel® Xeon® CPU X5650 @ 2.67GHz (24 cores) Memory:96 GiB HostName: When using Plex server/client latest stable version I have no audio drops or video stutters when viewing live TV. When using Emby either latest stable or beta version server with latest stable client I have consistent issues when using either Android TV client. While ebr suggested that it was a server issue I would expect that if that were the case Plex should also exhibit the same type of issue. I have attached snippet of emby-server.log along with time of events. emby.zip
Luke 42246 Posted August 26, 2019 Posted August 26, 2019 I have done several days of testing with different clients (Plex, Emby) and different Emby versions on two different Android TV end points (Shield, Mecool). Server Hardware/Software OS Version:FreeNAS-11.2-U5 (Build Date: Jun 24, 2019 18:41) Processor:Intel® Xeon® CPU X5650 @ 2.67GHz (24 cores) Memory:96 GiB HostName: When using Plex server/client latest stable version I have no audio drops or video stutters when viewing live TV. When using Emby either latest stable or beta version server with latest stable client I have consistent issues when using either Android TV client. While ebr suggested that it was a server issue I would expect that if that were the case Plex should also exhibit the same type of issue. I have attached snippet of emby-server.log along with time of events. Can you please attach the ffmpeg log as well? thanks.
MoonPie2000 0 Posted August 26, 2019 Author Posted August 26, 2019 (edited) Here are all ffmeg logs during the testing time frame. Also just so you are aware i created 3 rc.conf settings - user/group and data dir - Media,Media,/config respectively. I also created a symlink for /var/db/emby-server folder pointing to /config just in case. I am using FreeNAS as you an see and I have 4 mount points /media/movies, /media/series, /media/music and /config. ffmpeg.zip Edited August 26, 2019 by MoonPie2000
MoonPie2000 0 Posted August 28, 2019 Author Posted August 28, 2019 For what it is worth I have a Roku express and when I play live TV on it thru Emby it plays without any issues - no audio drops no video stutters.
ebr 16338 Posted August 28, 2019 Posted August 28, 2019 For what it is worth I have a Roku express and when I play live TV on it thru Emby it plays without any issues - no audio drops no video stutters. Do you have an ffmpeg log from that playback for comparison? Thanks.
Luke 42246 Posted September 2, 2019 Posted September 2, 2019 @@MoonPie2000 are you able to provide that? Thanks !
MoonPie2000 0 Posted September 3, 2019 Author Posted September 3, 2019 (edited) Here you go. At the first and towards the end the channel I tuned was weak and gave several 'loading' screens but that is not uncommon for that channel. roku.zip Edited September 3, 2019 by MoonPie2000
Luke 42246 Posted September 3, 2019 Posted September 3, 2019 Here you go. At the first and towards the end the channel I tuned was weak and gave several 'loading' screens but that is not uncommon for that channel. @@MoonPie2000 and you only see this happen on the Shield and not Roku?
ebr 16338 Posted September 3, 2019 Posted September 3, 2019 @@MoonPie2000 and you only see this happen on the Shield and not Roku? Actually, it sounds like the same thing is happening it just shows up differently... At the first and towards the end the channel I tuned was weak and gave several 'loading' screens MoonPie - this sounds like the behavior with a sketchy signal. Is it just this channel?
MoonPie2000 0 Posted September 3, 2019 Author Posted September 3, 2019 (edited) I think you have misunderstood what I meant by my mention of loading error. I agree that this error was probable caused by a weak signal because I was not receiving a strong signal at the time I was tuned to the particular channel that was giving the loading error however I tuned in multiple channels to give you a cross section of logging. On the other channels I did not receive this error. I just wanted you to be aware of the issue when going thru the logs in case it might affect your evaluations. I have included a brief summary of my testing methodology and what my observations have been so far. Hopefully this will further help your evaluations and if any explicit instructions are required in the future. I only have a a few weeks left on my premier subscription. I was planning to switch to Emby once this Live TV issue gets fixed. I really like Emby however this issue is a deal breaker for me. Thanks... I have 3 end clients, Shield, Mecool (android TV), Roku. I have Plex and Emby agents on all three end clients. I have a HD Homerun device that broadcast my OTA signal to all my end clients and as expected occasionally the OTA signal reception varies on some channels. To insure that the tests are not the result of a weak signal or hardware I compare both agents (Plex, Emby) on the same end client using the same channels. I use the Plex signal strength indicator, on the channel menu, to validate that the channel is at 100% signal strength. Below are my observations when testing agents on the same channels for both agents and all channels have a constant 100% signal strength Shield Plex - no audio drops/video stutters Emby - random audio drops/video stutters Mecool Plex - no audio drops/video stutters Emby - random audio drops/video stutters Roku Plex - no audio drops/video stutters Emby - no audio drops/video stutters Edited September 4, 2019 by MoonPie2000
MoonPie2000 0 Posted September 12, 2019 Author Posted September 12, 2019 (edited) I am running beta server 4.3.0.8 and Android-TV client 1.7.50g and the issue seems to be a little better but still present. I cleared cache and uninstalled - installed client again to make sure there was no residual settings. I did an upgrade on the server from the previous beta. When I get a chance I will do a fresh install of the server beta in a FreeNAS jail. Edited September 12, 2019 by MoonPie2000
ebr 16338 Posted September 12, 2019 Posted September 12, 2019 I am running beta server 4.3.0.8 and Android-TV client 1.7.50g and the issue seems to be a little better but still present. I cleared cache and uninstalled - installed client again to make sure there was no residual settings. I did an upgrade on the server from the previous beta. When I get a chance I will do a fresh install of the server beta in a FreeNAS jail. I would try testing this against the release server as well to see if we can isolate it to changes in the beta. Thanks.
