floz 0 Posted August 22, 2019 Posted August 22, 2019 Hey guys 1st post in these forums Just purchased a new CPU Intel Xeon Processor E5-4650 v2 Possibly 48Gb Ram but atm 24gb 550W PSU 40Tb HDD (total) and was wondering what sort of gpu would be best suited to be added? I am currently running an old Radeon 280x however I am in a position to upgrade the GPU however I have not seen any recommendations regarding AMD cards but willing to listen to any sort of feedback as I was tempted for an RTX to future proof myself which is the most likely option but as I am new to upgrading my server after so long would like to hear any feedback from yourselves
Guest asrequested Posted August 22, 2019 Posted August 22, 2019 I'm using a Threadripper, so it's much better than a Xeon. If you're looking to transcode 4k stuff, you'll need a GPU for that. Which one you buy is largely dependant on your budget.
floz 0 Posted August 22, 2019 Author Posted August 22, 2019 I'm using a Threadripper, so it's much better than a Xeon. If you're looking to transcode 4k stuff, you'll need a GPU for that. Which one you buy is largely dependant on your budget. been looking at a 2060/2070 but potentially looking at taking my 1080ti out of my gaming system and purchasing a 2080ti or 2080 any advice from yourself will be helpful
Guest asrequested Posted August 22, 2019 Posted August 22, 2019 Any one of those cards will work well. The question you need to worry about is how many simultaneous transcodes you require. Those can only handle two, but there is a patch to unlock them. Several of these guys have done that.
Happy2Play 9811 Posted August 22, 2019 Posted August 22, 2019 Have you seen this chart linked in another topic.
floz 0 Posted August 22, 2019 Author Posted August 22, 2019 Any one of those cards will work well. The question you need to worry about is how many simultaneous transcodes you require. Those can only handle two, but there is a patch to unlock them. Several of these guys have done that. many thanks Have you seen this chart linked in another topic. yes I have, i have recently found this community and this was something which explains it very well i was just seeing for my own system I was wondering if anyone had any advice if I should upgrade anything at this point in time or is it just the GPU slowing me down
floz 0 Posted August 27, 2019 Author Posted August 27, 2019 just purchased a msi 2070 for £360 update purchased a 2080ti and going to put a 1080ti in the server
