phi303 14 Posted August 22, 2019 Posted August 22, 2019 I'm specifically looking for My Media headers like "MOVIES", "TV SHOWS", "COLLECTIONS", and "PLAYLISTS" - just the main header images I customized. I've been looking through appData folder, found a bunch of stuff like user pics but I can't seems to find the header images, any help would be great!
Solution Happy2Play 9806 Posted August 22, 2019 Solution Posted August 22, 2019 (edited) Have you looked in "\Emby-Server\programdata\root\default\librarynamed folders"? Edited August 22, 2019 by Happy2Play 1
phi303 14 Posted August 22, 2019 Author Posted August 22, 2019 Have you looked in "\Emby-Server\programdata\root\default\librarynamed folders"? it was actually in \AppData\Roaming\Emby-Server\root\default\xxxxxxxxxxx but your post helped tremendously, thank you!
Happy2Play 9806 Posted August 22, 2019 Posted August 22, 2019 it was actually in \AppData\Roaming\Emby-Server\root\default\xxxxxxxxxxx but your post helped tremendously, thank you! Assuming you have a default installation yes, as mine is actually "C:\Emby-Server\programdata\root\default\xxx"
