blueray 0 Posted August 21, 2019 Posted August 21, 2019 watching iptv but the guide isn't matching what is really on. Any thoughts?
Luke 42237 Posted August 21, 2019 Posted August 21, 2019 Hi there, why do you feel it is incorrect? Please discuss an example? What guide data source did you use?
ebr 16332 Posted August 21, 2019 Posted August 21, 2019 Hi. Your provider should have given you an url for guide data. Are you using that?
blueray 0 Posted August 22, 2019 Author Posted August 22, 2019 On some of the movie channels, the guide shows one title but something else is on. Yes, I'm using the guide supplied by Apollo.
ebr 16332 Posted August 22, 2019 Posted August 22, 2019 Okay, then the data is coming from them not us. Is it possibly a time zone issue?
blueray 0 Posted August 22, 2019 Author Posted August 22, 2019 Possibly but not all channels are wrong. Is there a guide you can recommend?
Luke 42237 Posted August 22, 2019 Posted August 22, 2019 What country are you in? @@Senna or @@maegibbons or @@cayars may have some guide source tips.
Carlo 4561 Posted August 22, 2019 Posted August 22, 2019 I'm not familiar with Apollo specifically but any M3U based service is going to be a challenge if the data they provide you isn't correct. They likely get channels from various sources which could be east or west coast based so trying to come up with your own data is an exercise in these cases. If Apollo has local channels then it's usually a lot easier to match those up. Roughly how many channels do you have that are correct and how many are wrong?
blueray 0 Posted August 23, 2019 Author Posted August 23, 2019 I'll check with them. Thank you for your help.
