Da7Sincere
What is the specfic method to Port forward or tunnel Emby on windows 10 to remote access when I do not have acces to my router or ability for static ip address.
Happy2Play
Without access to your router there isn't anything your can do that I am aware of.
Da7Sincere
there is no method through vpn or like portmap.io??
I'm sure you can do that but we don't have any guides on how you could set this up.
movieserver1
I know this has probably been answered a thousand times, and I've read many.   I have port forwarded the 8096 on the modem and using the canyouseeme.org  It says that its working however, When I click on the WAN or LAN address on my settings it will not work nor am I able to remote in using Connect.   Everything works good if I'm connected to wifi in the house.  I can't remote in and I'm stuck.
pwhodges
Are you trying to use https, which is on a different port (8920)?
hi there @@movieserver1, i would suggest checking out our connection troubleshooter. Please try the steps listed there and let us know which ones succeed and which ones do not. thanks !
movieserver1
In Network http://Localhost:8096 = Works
In Home Lan local 10.0.0.7:8096 = Works
Remote WAN access http://24.-.-.-.-.:8096 DOES NOT WORK
Canyouseeme.org   -  Successful
Using Norton Security suite for my firewall:
EmbyServer - Allowed
ffmpeg - Allowed
ffprobe - Allowed
Can't not access using Connect
Happy2Play
ffmpeg - Allowed
ffprobe - Allowed
So are you saying connection to the machine Emby is installed on from a different machine works?  Or just the machine Emby is installed on works?
Happy2Play
No device can connect Remotely using the WAN access my IP  http://24.-.-.-.-.:8096
that includes the server.
Right but can other devices connect on the LAN?
ffmpeg - Allowed
ffprobe - Allowed
What about the ports?
https://github.com/MediaBrowser/Wiki/wiki/Connectivity#open-tcp-port-8096-on-your-servers-firewall
movieserver1
as I said Canyouseeme.org   -  Successful using port 8096
but still can't access remotely
"We're unable to connect to the selected sever right now please ensure it is running and try again."
Edited by movieserver1
Q-Droid
Are any of the devices coming in remotely from the internet? If they are all LAN devices trying to use the external URL some routers do not allow NAT loopback connections. You can try a smartphone with wifi disabled, cell data only to see if your Emby server is visible.
bitteronthefruit
I can't access my emby server hosted on my Windows media server unless I am using the same isp (home internet connection). If I use another internet connection, LTE, etc it will not connect. I have tried everything I can think of. I have forward the port with my router, nothing.  I also installed airVPN software on my server and set it up. I then changed my VPN port forward settings to allow 8096 and also 8920. It shows a green light Still can't connect.
hi there @@bitteronthefruit, i would suggest checking out our connection troubleshooter. Please try the steps listed there and let us know which ones succeed and which ones do not. thanks !
Guest asrequested
Without the VPN, can you connect?
Happy2Play
I don't see how canyouseeme.org can connect and see the port open but you can connect to the ip:port directly.
Is the dashboard showing the same ip as canyouseeme.org?
Guest asrequested
If he has the VPN app running on the machine, and Emby hasn't updated to the new IP, then that could mess with it. Also, If the VPN is running and Emby has updated the IP, but UPNP is enabled in the server, that could be causing an issue with the VPN. We're missing a piece of the puzzle...
Edited by Doofus
Happy2Play
You should see a mismatch with the externalip, correct?
movieserver1
Same Remote (WAN) access IP on my dashboard as it is on canyouseeme.  Success: I can see your service on 24._,-,-, on port (8096)
Your ISP is not blocking port 8096
I do not have a VPN
Yes my internal NET IP is different than the WAN Remote
Guest asrequested
I do no have a VPN
Huh? You aren't making any sense!
EDIT:  Ooops! :D
Edited by Doofus
Happy2Play
:) Two different users/posters.
Edited by Happy2Play
Guest asrequested
Possibly, depending on what he did and if he knew what to look for.
We are definitely missing information....
Guest asrequested
OH! LMAO..... I didn't even notice :D  My bad!
Edited by Doofus
Guest asrequested
It could simply be something on the device he's testing with.
Can you try another device?
