Baiterline 0 Posted August 20, 2019 Posted August 20, 2019 Not sure this is the right tread to put it in to and im sorry for that! But, i can't connect with my Phone or Tv? Yeste day i could! on my TV! And then i shut off my tv and wanted to see a movie later but then the problems started!-It saying We're unable to connect to the selected server right now. Please ensure it is running and try again! Then i restarted the server! = nothing changed! Reinstalled the software = nothing changed! Tryed to connect as it was a new media server = nothing changed! Restart my network! = nothing changed! Connecting to the remote connectiong = nothing changed! Tryed update the server = nothing changed! What can i do? On my pc the movies and all that works great! but Phone and TV not at all?!
Luke 42219 Posted August 20, 2019 Posted August 20, 2019 Hi there, have you tried doing a manual connection by entering the ip address of the server manually?
Luke 42219 Posted August 21, 2019 Posted August 21, 2019 So the only machine you can connect from is the server machine directly, right?
Luke 42219 Posted August 22, 2019 Posted August 22, 2019 I would suggest checking out our connection troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
