nonyhaha 4 Posted August 20, 2019 Posted August 20, 2019 (edited) Hello, I have read a few threads on the forum, but I seem to be going nowhere. I have an issue others users have too, but I did not manage to resolve it. The episodes do not scrape OK. The seasons scrape up as per folders, but the episodes inside don't. As per the Github guide, I used: show name S01E01 - Episode Name.ext anything_1x02.ext 02 Episode Name.ext May have been others too, but nothing worked. I used Filebot to rename everything according to thetbdb.com . (this results in: "show name 01x02 - episode name.xxx") Folder structure - I tried simple "xxxx\show name\1927\episodes" and "xxxx\show name\Season 1927\episodes" I tried, as per https://emby.media/community/index.php?/topic/38665-disney-animated-shorts-not-scraping-properly/page-3 to stop emby, delete library.db, start emby again. I deleted the entire library and recreated, to be sure nothing is wrong, the library type is set to "tv shows". The only agent is now set only to thetvdb, so there are no conflicts with other parties. Here are some photos: Any other thoughts, please let me know EDIT: One misspelling in the title, if anybody can help Edited August 20, 2019 by nonyhaha
Luke 42217 Posted August 20, 2019 Posted August 20, 2019 Hi, s1927.e15 is not part of our supported naming conventions so I'm not sure that will work.
nonyhaha 4 Posted August 20, 2019 Author Posted August 20, 2019 That is one episode only for testing purposes. There are 4 or 5 different namings and none are recognised.
Luke 42217 Posted August 20, 2019 Posted August 20, 2019 It looks like they are recognized because the server was able to extract season and episode numbers. Did you check tvdb to see if there is a series with the same title, season and episode numbers? Is that how they're doing it on tvdb, season 1927?
nonyhaha 4 Posted August 21, 2019 Author Posted August 21, 2019 Hello Luke, Season 27 recognises only one episode. You can see that in the folder there are many episodes not recognised. Thetvdb has this kind of naming for some shows, like disney animated shorts, looney tunes, mgm cartons...
StewieGreen 160 Posted August 21, 2019 Posted August 21, 2019 I'm not sure if this will help you but I have a collection of old looney tunes and used filebot to name them, all the files came up like this: "Looney Tunes - SXXXXEXX - Episode Name" All the files are labelled with Looney Tunes, then S & the year they aired, E for episode number followed by - episode name xxxxxx/Looney Tunes/Season 1931/Looney Tunes - SXXXXEXX - Episode Name.mkv Emby identified all of them with no problems.
nonyhaha 4 Posted August 21, 2019 Author Posted August 21, 2019 (edited) Hi Adam. I do not know why but for me filebot does not name them like that. Do you remember exactly how you managed this? L.E. I found out that in filebot you can edit the renaming structure. Now all looks ok, except seasons lower than 1928 in disney animated shorts. Looney tunes dows not go lower than 1929 so... it is ok. Edited August 21, 2019 by nonyhaha
StewieGreen 160 Posted August 21, 2019 Posted August 21, 2019 nonyhaha: yeah, the dev has shortcuts to plex naming conventions too, and they work perfectly with Emby.
nonyhaha 4 Posted August 21, 2019 Author Posted August 21, 2019 I think there is a problem with fetching data from thetvdb for seasons up to 1928. I am looking at metadata manager. Recognized episodes get info about the correct year, episode name and description, and also thetvdb ID. Episodes that are not recognized (up to 1928) do not have this info. I entered manually the season and episode number and also thetvdb id for one of the episodes, tried refreshing metadata, but nothing gets added. Only what I entered.
Happy2Play 9806 Posted August 21, 2019 Posted August 21, 2019 It could be TVDB related as they are still doing a lot of v3 updating. But it is really hard to say without replicating exact structure and naming scheme being used.
Luke 42217 Posted August 21, 2019 Posted August 21, 2019 I think there is a problem with fetching data from thetvdb for seasons up to 1928. I am looking at metadata manager. Recognized episodes get info about the correct year, episode name and description, and also thetvdb ID. Episodes that are not recognized (up to 1928) do not have this info. I entered manually the season and episode number and also thetvdb id for one of the episodes, tried refreshing metadata, but nothing gets added. Only what I entered. Please attach the information requested in how to report a problem. thanks.
Deathsquirrel 745 Posted August 21, 2019 Posted August 21, 2019 @@nonyhaha I created a Disney Animated Shorts Season 1926 for testing. I created the following files by copying and renaming another disney short, and then scanned my library: \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E01 Alice on the Farm.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E02 Alice's Orphan.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E03 Alice's Little Parade.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E04 Alice's Mysterious Mystery.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E05 Alice's Balloon Race.mkv My results were similar. Looking at my debug logs it looks like a metadata provider issue. Post your logs as luke suggested, but this may just be a TVDB problem right now. 1
Happy2Play 9806 Posted August 22, 2019 Posted August 22, 2019 (edited) @@nonyhaha I created a Disney Animated Shorts Season 1926 for testing. I created the following files by copying and renaming another disney short, and then scanned my library: \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E01 Alice on the Farm.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E02 Alice's Orphan.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E03 Alice's Little Parade.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E04 Alice's Mysterious Mystery.mkv \\MyServerName\MyMovieShare\TV Shows\Disney Animated Shorts\Season 1926\Disney Animated Shorts S1926E05 Alice's Balloon Race.mkv My results were similar. Looking at my debug logs it looks like a metadata provider issue. Post your logs as luke suggested, but this may just be a TVDB problem right now. Did the exact same test and I ended up with multi-version of all these episodes instead of individual episodes. @@Luke So there is a parsing issue (4 digit seasons) that shows this as Season19 Episode 26 and merges all the episode as multi-version. You can see the issue in Next up with the identified naming. My test was on 4.3.0.4 The en.xml from tvdb is correct. Example season 1926 episode 1 <Episode> <id>4570038</id> <Combined_episodenumber>1</Combined_episodenumber> <Combined_season>1926</Combined_season> <DVD_chapter></DVD_chapter> <DVD_discid></DVD_discid> <DVD_episodenumber></DVD_episodenumber> <DVD_season></DVD_season> <Director>Walt Disney</Director> <EpImgFlag>1</EpImgFlag> <EpisodeName>Alice on the Farm</EpisodeName> <EpisodeNumber>1</EpisodeNumber> <FirstAired>1926-01-01</FirstAired> <GuestStars>Alice, Julius, Pete</GuestStars> <IMDB_ID>tt0016586</IMDB_ID> <Language>en</Language> <Overview>Julius is milking his musical cow when Pete kidnaps Alice. Julius chases him on a sawhorse and then wins Alice back in a duel.</Overview> <ProductionCode>ACL-16</ProductionCode> <Rating></Rating> <RatingCount>0</RatingCount> <SeasonNumber>1926</SeasonNumber> <Writer>Walt Disney</Writer> <absolute_number></absolute_number> <filename>episodes/78988/4570038.jpg</filename> <is_movie>0</is_movie> <lastupdated>1369176883</lastupdated> <seasonid>520141</seasonid> <seriesid>78988</seriesid> <thumb_added></thumb_added> <thumb_height>300</thumb_height> <thumb_width>400</thumb_width> </Episode> Edited August 22, 2019 by Happy2Play 1
Deathsquirrel 745 Posted August 22, 2019 Posted August 22, 2019 Nice catch @@Happy2Play! I just had time to scan and see a season lookup error in the logs before I had to jet. My results match yours.
Happy2Play 9806 Posted August 22, 2019 Posted August 22, 2019 Hmm, I had no issue adding Looney Tunes Looney Tunes Season 1930 Looney Tunes.S1930E02.Congo Jazz.disc Looney Tunes.S1930E04.The Booze Hangs High.disc So there would possible provider issue specific to that Series.
nonyhaha 4 Posted August 22, 2019 Author Posted August 22, 2019 Hello. This is an issue only wit season naming up until 1928. Anything over that is a-ok.
StewieGreen 160 Posted August 22, 2019 Posted August 22, 2019 It may be broken for movies too ... I didn't link them until now but I got Nosferatu (1922) a couple weeks ago and I had to specifically search the TMDB # in "identify" in order to get the right metadata.
Luke 42217 Posted August 22, 2019 Posted August 22, 2019 It may be broken for movies too ... I didn't link them until now but I got Nosferatu (1922) a couple weeks ago and I had to specifically search the TMDB # in "identify" in order to get the right metadata. That means we plugged that into Tmdb search and that's what it came back with. Also: https://emby.media/community/index.php?/topic/76457-moviedb-down/
nonyhaha 4 Posted August 23, 2019 Author Posted August 23, 2019 I am sounding the alarm again Sorry Luke. As I am still working on my collections, I found out that collections that are not complete (in the looney tunes show) will not scrape correctly. Up to season 1934 i have them all, they scrape ok, are identified, all is ok: BUT, for the next season, which is incoplete: The naming inside the folders is the same. ex: Looney Tunes - S1935E10 - Into Your Dance.mkv I am still in the process of downloading some episodes, but this might be an issue in emby. Also, I checked ant this is an issue also in Disney animated shorts...
Luke 42217 Posted August 23, 2019 Posted August 23, 2019 Try manually fixing the season and episode numbers for those episodes if they are not right. Then refresh the metadata and compare what you get to what is on tvdb.
nonyhaha 4 Posted August 24, 2019 Author Posted August 24, 2019 Hi. Sorry for the late reply. I was out for a little bit . This morning when i came back to the server, all was ok with looney tunes. Might have been an issue with tvdb again. Unfortunately disney shorts up to 1928 still represent a problem.
Luke 42217 Posted August 24, 2019 Posted August 24, 2019 Try manually fixing the season and episode numbers for those episodes if they are not right. Then refresh the metadata and compare what you get to what is on tvdb.
nonyhaha 4 Posted August 24, 2019 Author Posted August 24, 2019 Hello! In season 1927 I edited the metadata for all episodes I have and there is a change, but it will not download anything new, even if I refresh all metadata of the season:
nonyhaha 4 Posted August 25, 2019 Author Posted August 25, 2019 It does not download anything new from thetvdb after a refresh all metadata. Not even the tvdb or imdb id. All fields are empty in metadaya manager. Only date added, path, title, season and episode number, last two being the ones i edited.
