DGMayor 90 Posted June 1, 2014 Posted June 1, 2014 (edited) When adding/updating metadata via MB3's internal fetchers for some shows, it will add the DVD episode number as 1.2 or 3.4 (I'm assuming it's disc dot episode # on that disc). This is all well and good, but when you try to edit something manually for that episode, the save fails because it wants an integer for the DVD Episode number field. I thought it may have been left over from my Metabrowser use, so I deleted the xml/image and let MB3 rebuild it, and it came right back. Edited June 1, 2014 by DGMayor
