paulie99 1 Posted August 19, 2019 Posted August 19, 2019 Hello all, Not sure if this is the correct place to post this, so I apologize if it isn't. I am unable to add users to my remote access by adding their email addresses in the emby connect box in the users page. Not sure what the issue is, but I have attached a log if anyone has a suggestion. Thanks very much in advance, Paul emby log-081919.txt
Happy2Play 9806 Posted August 19, 2019 Posted August 19, 2019 To me there is a external connect issue as other services are failing also. 2019-08-19 14:00:34.716 Error App: Error registering with Connect 2019-08-19 14:00:35.253 Error App: Error downloading news 2019-08-19 14:00:37.076 Error TaskManager: Error (MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json)
Luke 42219 Posted August 19, 2019 Posted August 19, 2019 Outgoing communications are failing. Does your server machine have an internet connection? Is it behind a VPN?
paulie99 1 Posted August 19, 2019 Author Posted August 19, 2019 I have a funky weird setup due to Rogers ignite (it's a pain, but the family likes it for some reason). I made some changes to my router, I will test and see if that works. It may also explain why the movie DB doesn't want to download posters or actor images. Thanks very much for the quick replies, much appreciated! Cheers, Paul
paulie99 1 Posted August 19, 2019 Author Posted August 19, 2019 Well that didn't seem to work. I ran the port check on canyouseeme on port 8096, and it shows as open. Would port 8920 needed to be forwarded as well? Cheers, Paul
Solution paulie99 1 Posted August 19, 2019 Author Solution Posted August 19, 2019 Well, apparently the third reboot did the job. I think there was some gummed up data on my server, but whatever was blocking the connections is now gone, and it tested perfectly. Thank you for the support, again, much appreciated! Cheers, Paul 1
