ZiemaF 0 Posted August 19, 2019 Posted August 19, 2019 Hi, I have a server on UnRaid, Docker is running on this server. EMBY works on Docker, with HW transcoding (VAAPI Intel i5-8600k), generally works great. I have a problem with films with 10bit color. If I play the movie directly (without transcoding) the colors are ok. If I turn on transcoding (to any resolution), the colors are so faded. Can i do something about it? Thank you for your help
Luke 42246 Posted August 19, 2019 Posted August 19, 2019 Hi, we haven't yet implemented any tone mapping for hdr to sdr transcoding. It's planned for the future. Thanks.
ZiemaF 0 Posted August 20, 2019 Author Posted August 20, 2019 Thank you for the information. Do you already have a deadline or are you planning tests? I will gladly take part in it. Here I found a solution to the problem https://stevens.li/guides/video/converting-hdr-to-sdr-with-ffmpeg/ Theoretically, my Intel i5-8600k should be able to handle hardware conversion of hdr (10bit) to sdr (8bit)
Jdiesel 1439 Posted August 20, 2019 Posted August 20, 2019 Thank you for the information. Do you already have a deadline or are you planning tests? I will gladly take part in it. Here I found a solution to the problem https://stevens.li/guides/video/converting-hdr-to-sdr-with-ffmpeg/ Theoretically, my Intel i5-8600k should be able to handle hardware conversion of hdr (10bit) to sdr (8bit) Are you sure about that? Did you catch the last paragraph of that article. "The tone-mapping algorithm place 100% load on a single CPU core. Null output of our tone-mapping setup results in an average playback speed of about 4.3 frames per second on an AMD Ryzen 7 1800X CPU running at 3.8 GHz." Zscale is single threaded, even a 1800x can only manage 4.3 frames per second which is nowhere near the minimum of 24 frames per second for real-time transcoding. ffmpeg will need to introduce a more efficient way of doing this, preferably hardware accelerated, before this is feasible.
