nebur 1 Posted August 18, 2019 Posted August 18, 2019 I have this error when i try to play any tvshow: - Error de reproducción - No tienes disponible ninguna calidad por ahora. Inténtalo más tarde o contacta con el administrador para más detalles. When I try to play any movie for example movie1 it's play movie25 and if I try to play movie1 again it's play movie33 or moviexxx never the same. And the problem isn't movie1 is the same with any movie. When I browse with any client though library the metadata it's correct with his movie or ... I have the backup plugin and with permissions not detect the backups for restore it. Regards embyserver.txt
Luke 42246 Posted August 18, 2019 Posted August 18, 2019 Hi, was there an ffmpeg log? can you please attach that too? thanks.
nebur 1 Posted August 18, 2019 Author Posted August 18, 2019 Hi, There are several. I attach one with error in tvshows that all fail. Thanks ffmpeg-transcode-f01961ac-283b-4f24-bf09-ddf4d7f91974_1.txt
Luke 42246 Posted August 18, 2019 Posted August 18, 2019 file:/mnt/media/hdTV/ruben/Videos/Series/Condor/Season 01/Condor 1x07.m4v: Permission denied The server does not have permission to read the file. Fix this and your problem will go away.
nebur 1 Posted August 18, 2019 Author Posted August 18, 2019 Hi, Now the other with right permissions. Regards ffmpeg-transcode-e5b6625b-b81a-4a47-9085-3051af42f595_1.txt
Luke 42246 Posted August 19, 2019 Posted August 19, 2019 Is the media on a hard drive? It still can't read it.
Solution nebur 1 Posted August 19, 2019 Author Solution Posted August 19, 2019 Hi, Sorry but the problem is solved. There was something wrong in docker. When was solved and recreated the emby process all are good. Thanks for the support. 1
