abstruseoni 0 Posted August 16, 2019 Posted August 16, 2019 I have a bunch of anime eps that I've been watching, and they were all named properly until yesterday. Yesterday my internet got turned back on (it was off for a week), and I added a few new episodes of the anime. Suddenly ALL the episodes have been renamed to "John Dies In The End", which is a movie I don't even have. I also notice that emby had an update which might have effected metadata.. Any thoughts on what I should try?
Solution Happy2Play 9806 Posted August 16, 2019 Solution Posted August 16, 2019 Well TVDB is having all kinds of issues migrating to v3 and TMDB has been having issues with their search endpoint. So without logs and knowing your library metadata downloader option it is just a guess. 1
abstruseoni 0 Posted August 16, 2019 Author Posted August 16, 2019 Thanks Happy2Play! I removed TVDB from my plugins. And then I removed the anime eps, and added them back into the library. Seems to have fixed the issue!
Luke 42218 Posted August 16, 2019 Posted August 16, 2019 I would just disable it for the anime library rather than removing it. If you have a regular TV library, then please add it back before coming back and reporting problems with regular TV.
