Maximus Naxsus 20 Posted August 15, 2019 Posted August 15, 2019 (edited) Hi All, What does the following indicate? 2019-08-15 17:29:22.135 Error App: Error resolving path \\dondersteendc\Media_DSdcTiered\TV Series\TV Series - Ended\Avatar The Last Airbender\Season 02 *** Error Report *** Version: 4.2.1.0 Command line: C:\Shares\Emby190814\system\EmbyServer.dll -service Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Shares/Emby190814/system/System.Private.CoreLib.dll Processor count: 8 Program data path: C:\Shares\Emby190814\programdata Application directory: C:\Shares\Emby190814\system System.IO.IOException: System.IO.IOException: An unexpected network error occurred : '\\dondersteendc\Media_DSdcTiered\TV Series\TV Series - Ended\Avatar The Last Airbender\Season 02' at System.IO.Enumeration.FileSystemEnumerator`1.GetData() at System.IO.Enumeration.FileSystemEnumerator`1.FindNextEntry() at System.IO.Enumeration.FileSystemEnumerator`1.MoveNext() at System.Linq.Enumerable.SelectEnumerableIterator`2.ToArray() at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, IServerApplicationHost appHost, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.ResolveFileList(List`1 fileList, IDirectoryService directoryService, Folder parent, IItemResolver[] resolvers, LibraryOptions libraryOptions) Source: System.IO.FileSystem TargetSite: Boolean GetData() I’m working on a VM with Emby and I'm currently in the testing phase. Most of it working well except that Emby seems to get stuck scanning a certain directory. As far as I can understand it must be folder permission related. Running the latest version What do you think? More info on request and thank for any help or suggestions, Peran embyserver.txt Edited August 15, 2019 by Maximus Naxsus
Luke 42219 Posted August 15, 2019 Posted August 15, 2019 that means an unexpected network error occurred when trying to get the list of files within that network folder. sounds like you have a network problem to look at. that being said, the scan is most likely not stuck. Most likely you just need to be patient and allow it to finish.
Maximus Naxsus 20 Posted August 15, 2019 Author Posted August 15, 2019 that means an unexpected network error occurred when trying to get the list of files within that network folder. sounds like you have a network problem to look at. that being said, the scan is most likely not stuck. Most likely you just need to be patient and allow it to finish. Network issue: what would be your first step to tackle this? More patients, check.
Luke 42219 Posted August 15, 2019 Posted August 15, 2019 Unfortunately I don't know because the error doesn't provide much information. I would make sure you can access that path through windows explorer. You may also want to reboot both the server machine and the machine holding the media.
Maximus Naxsus 20 Posted August 15, 2019 Author Posted August 15, 2019 Unfortunately I don't know because the error doesn't provide much information. I would make sure you can access that path through windows explorer. You may also want to reboot both the server machine and the machine holding the media. Done before posting :-) Could the 'enable debug logging' check box help?
Luke 42219 Posted August 15, 2019 Posted August 15, 2019 Yes potentially. Make sure to restart the server after that.
Maximus Naxsus 20 Posted August 15, 2019 Author Posted August 15, 2019 (edited) Yes potentially. Make sure to restart the server after that. I will use the patience method first and then try the debug option. Edited August 15, 2019 by Maximus Naxsus
Solution Maximus Naxsus 20 Posted August 19, 2019 Author Solution Posted August 19, 2019 Changing the Jumbo Packet settings of the vNIC to 4088 (from 9014) seem to fixed it >.< Any ideas on what’s going on are very much apricated! 1
pir8radio 1313 Posted August 20, 2019 Posted August 20, 2019 Changing the Jumbo Packet settings of the vNIC to 4088 (from 9014) seem to fixed it >.< Any ideas on what’s going on are very much apricated! Jumbo packets are kind of old news... Your nic, managed switch, and client all need to support JP for it to work, doesnt do anything for the internet. And there really isn't much use for it now-a-days. I mean I have two 1gbps internet connections with an MTU of 1500 on both and the overhead isnt even really noticeable. I hit pretty close to theoretical at about 1.7gbps. I wouldn't worry to much about Jumbo Frames.
Guest asrequested Posted August 20, 2019 Posted August 20, 2019 Jumbo packets are very useful on my 10G network
pir8radio 1313 Posted August 20, 2019 Posted August 20, 2019 Jumbo packets are very useful on my 10G network meh..... The CPU's in the nics, switches and end devices today can deal with the increased rx/tx packets of smaller MTU's The olden days the nic CPU used to max out.
Guest asrequested Posted August 20, 2019 Posted August 20, 2019 lol.... I just wanted to see what you'd say
