wintersport 0 Posted August 15, 2019 Posted August 15, 2019 (edited) Hi there! Im running Emby 4.2.1.0 and a TVMosaic server for Live TV. When i edit the channels i want to be visable in Emby on the TVMosaic server and i refresh the TV Guide Data and Internet Channels on the scheduled tasks within Emby. The old channels i dont wanna be visuable anymore wont dissapear in Emby. New ones do show.. old ones just cant be removed.. Also, it doesnt get the channel icons/images from the TVMosaic server, i have the option turned on. Is there anyone who can help me with this? Kind Regrads, Robin A response is Dutch is also fine Im dutch. Edited August 15, 2019 by wintersport
Geeked 5 Posted August 15, 2019 Posted August 15, 2019 Same thing happened to me. I had to delete tuner link and guide, restart emby, then add back the tuner link and guide link. After that, update the guide once again.
Luke 42244 Posted August 15, 2019 Posted August 15, 2019 Same thing happened to me. I had to delete tuner link and guide, restart emby, then add back the tuner link and guide link. After that, update the guide once again. Hi, that's not the same thing. He's using a live tv plugin, therefore he has no tuner or guide to delete.
wintersport 0 Posted August 15, 2019 Author Posted August 15, 2019 Hi, I got a trial from TVMosaic Plus and now everything is good, even the icons are there. Thanks! But this can be closed. Kind regrads, Robin
