jonasem 0 Posted August 14, 2019 Posted August 14, 2019 I am unable to run 4.2.1.0 on NixOS. Last known running version is 4.0.1.0. I am getting the following error: Aug 14 18:42:31 nixos systemd[1]: Started Emby Media Server. Aug 14 18:42:31 nixos emby[13309]: Unhandled Exception: System.IO.IOException: Read-only file system Aug 14 18:42:31 nixos emby[13309]: at System.IO.FileSystem.CreateDirectory(String fullPath) Aug 14 18:42:31 nixos emby[13309]: at System.IO.Directory.CreateDirectory(String path) Aug 14 18:42:31 nixos emby[13309]: at EmbyServer.Support.ApplicationPathProvider.GetProgramDataPath(String applicationPath, IEnvironmentInfo environment) Aug 14 18:42:31 nixos emby[13309]: at EmbyServer.Support.ApplicationPathProvider.CreateApplicationPaths(String applicationPath, String programDataPath, IEnvironmentInfo environment) Aug 14 18:42:31 nixos emby[13309]: at EmbyServer.Program.Main(String[] args) Aug 14 18:42:31 nixos systemd[1]: emby.service: Main process exited, code=killed, status=6/ABRT Aug 14 18:42:31 nixos systemd[1]: emby.service: Failed with result 'signal'. Aug 14 18:42:31 nixos systemd[1]: emby.service: Service RestartSec=100ms expired, scheduling restart. Aug 14 18:42:31 nixos systemd[1]: emby.service: Scheduled restart job, restart counter is at 4. Aug 14 18:42:31 nixos systemd[1]: Stopped Emby Media Server. Has Emby started requiring write permissions in any other directory than the "-programdata"-directory?
jonasem 0 Posted August 14, 2019 Author Posted August 14, 2019 I am not sure what was wrong but it is working for me now. Here is my config if anyone runs into a similar issue: { stdenv, fetchurl, unzip, sqlite, makeWrapper, dotnet-sdk, ffmpeg }: stdenv.mkDerivation rec { name = "emby-${version}"; version = "4.3.0.2"; # We are fetching a binary here, however, a source build is possible. # See -> https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=emby-server-git#n43 # Though in my attempt it failed with this error repeatedly # The type 'Attribute' is defined in an assembly that is not referenced. You must add a reference to assembly 'netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. # This may also need msbuild (instead of xbuild) which isn't in nixpkgs # See -> https://github.com/NixOS/nixpkgs/issues/29817 src = fetchurl { url = "https://github.com/MediaBrowser/Emby.Releases/releases/download/${version}/embyserver-netcore_${version}.zip"; sha256 = "0v2z9gqm3c33q49579z30zff39k8r4513lzkzqz6yjh4cikvpl5g"; }; buildInputs = [ unzip makeWrapper ]; propagatedBuildInputs = [ dotnet-sdk sqlite ]; preferLocalBuild = true; buildPhase = '' rm -rf {electron,runtimes} ''; installPhase = '' install -dm 755 "$out/opt/emby-server" cp -r * "$out/opt/emby-server" makeWrapper "${dotnet-sdk}/bin/dotnet" $out/bin/emby \ --prefix LD_LIBRARY_PATH : "${stdenv.lib.makeLibraryPath [ sqlite ]}" \ --add-flags "$out/opt/emby-server/EmbyServer.dll -ffmpeg ${ffmpeg}/bin/ffmpeg -ffprobe ${ffmpeg}/bin/ffprobe" ''; meta = with stdenv.lib; { description = "MediaBrowser - Bring together your videos, music, photos, and live television"; homepage = https://emby.media/; license = licenses.gpl2; maintainers = with maintainers; [ fadenb ]; platforms = platforms.all; }; }
Luke 42246 Posted August 14, 2019 Posted August 14, 2019 Hi there, thanks for the feedback. To answer this question: Has Emby started requiring write permissions in any other directory than the "-programdata"-directory? The answer is no, we have not.
