johnvick 1 Posted August 14, 2019 Posted August 14, 2019 My system is Ubuntu 18.04 running on Pentium J45 Apollo Lake mini-PC kernel 4.18. Emby is 4.2.1.0. Harware transcoding works but not consistently with 1080 HEVC 10 bit encoded files. Some files play well and some don't and crash the machine leaving a log like this: Affected codecs:>>>>>> VAAPI Celeron N3350/Pentium N4200/Atom - H.265 (HEVC)Adapter #0: 'Celeron N3350/Pentium N4200/Atom' Id:23172 (Driver: Intel i965 driver for Intel® Broxton - 2.3.0, Vendor: Intel Corporation)Frame Sizes: max 4096x4096Color Formats: NV12, P010, NV16Profiles: Main Profile (Level 6 (Main)), Main 10 Profile (Level 6 (Main))>>>>>> VAAPI Celeron N3350/Pentium N4200/Atom - H.264 (AVC)Adapter #0: 'Celeron N3350/Pentium N4200/Atom' Id:23172 (Driver: Intel i965 driver for Intel® Broxton - 2.3.0, Vendor: Intel Corporation)Frame Sizes: 32x32...4096x4096Color Formats: NV12, P010Profiles: Constrained Baseline Profile (Level 6), Main Profile (Level 6), High Profile (Level 6)>>>>>> FindVideoDecoder - MediaType: hevc, Mode: CustomInfo FindVideoDecoder - Checking: 'VAAPI Celeron N3350/Pentium N4200/Atom - H.265 (HEVC)' (Priority: 100)Info FindVideoDecoder - Check successful - selecting 'VAAPI Celeron N3350/Pentium N4200/Atom - H.265 (HEVC)'>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: CustomInfo FindVideoEncoder - Checking: 'VAAPI Celeron N3350/Pentium N4200/Atom - H.264 (AVC)' (Priority: 100)Info Encoder supports input streamInfo FindVideoEncoder - Check successful - selecting 'VAAPI Celeron N3350/Pentium N4200/Atom - H.264 (AVC)'>>>>>> FindVideoDecoder - MediaType: hevc, Mode: CustomInfo FindVideoDecoder - Checking: 'VAAPI Celeron N3350/Pentium N4200/Atom - H.265 (HEVC)' (Priority: 100)Info FindVideoDecoder - Che Stopping in mid sentence. But if I play a good file first and then one of the files that crashes the system it then works. Strange I know but the way it is I can't let my famly use the system unless I am around to restart it if it crashes. Any suggestions to troubleshoot this? Thanks, John
Luke 42246 Posted August 14, 2019 Posted August 14, 2019 Hi there, can we look at an example? Please attach the information requested in how to report a media playback issue. Also, did you follow our hardware acceleration setup guide? thanks !
johnvick 1 Posted August 14, 2019 Author Posted August 14, 2019 Thanks for the speedy reply - I've followed the guides and things work pretty well except after a reboot when certain files don't play and crash the device. After I play a file that I know works first time all is fine - I can restart Emby and the file that crashed the device now works. I've attached some logs from the last induced crash. John embyserver-63701408645.txt ffmpeg-transcode-a929b9f3-8865-4a51-ac0b-feeb129133da_1.txt hardware_detection-63701408660.txt
