Fyb3roptik 1 Posted August 13, 2019 Posted August 13, 2019 I can use the ip address externally no problem, but if I try to use Emby site it does not connect. Says failed to connect. If I copy my ip into it, it still fails. Again I can access it directly in chrome via external ip and port, just not through Emby app
Luke 42246 Posted August 13, 2019 Posted August 13, 2019 Hi there, I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
Fyb3roptik 1 Posted August 14, 2019 Author Posted August 14, 2019 I should reiterate, it was linked and I could access it. I accidentally deleted the server. When trying to add it back I now get this message. Again I am fully 100% able to access this server remotely via direct ip:port connection
Fyb3roptik 1 Posted August 14, 2019 Author Posted August 14, 2019 I should also note, it doesnt even attempt to connect to it. It is an immediate I click connect and I get the error message
Fyb3roptik 1 Posted August 15, 2019 Author Posted August 15, 2019 Here is the console log from when I try to manually connect to my server. I have tried this in Incognito mode as well and getting the same thing.
Luke 42246 Posted August 15, 2019 Posted August 15, 2019 Please attach the complete console contents. Thanks.
Fyb3roptik 1 Posted August 15, 2019 Author Posted August 15, 2019 Notice it doesnt even try to attempt a connection. I get the error right as I click the Connect button. Check those timestamps
Luke 42246 Posted August 15, 2019 Posted August 15, 2019 There's now way that can be the complete console contents from the time you loaded the page, right?
Fyb3roptik 1 Posted August 15, 2019 Author Posted August 15, 2019 I had cleared it out before hitting connect. Here it is from page load
Fyb3roptik 1 Posted August 16, 2019 Author Posted August 16, 2019 Ok this appears to be a Chrome issue with your websites. If I use firefox it works as intended. Please fix this on chrome!
Luke 42246 Posted August 16, 2019 Posted August 16, 2019 Works fine here, I don't think there's anything to fix. That console output suggests you don't have any servers. Did you try a manual connection by entering your server ip address?
Fyb3roptik 1 Posted August 16, 2019 Author Posted August 16, 2019 Yes of course, that IS WHAT I AM DOING! If I do it in Firefox it works as expected. If I use Chrome it does not work at all
Luke 42246 Posted August 16, 2019 Posted August 16, 2019 Do you have any Chrome extensions installed?
