Sw4rl3y 0 Posted August 13, 2019 Posted August 13, 2019 (edited) Hi, i´ve set up LiveTV via mu3 and Octopus NET. LiveTV works fine, everything good here but i´m not able to record any show whatsoever. Log says: 2019-08-13 19:44:43.475 Info LiveTV: Recording timer fired for Vikings. 2019-08-13 19:44:43.476 Error LiveTV: Error recording to /var/lib/emby/data/livetv/recordings/Vikings/Vikings 2019_08_13_18_14_30.ts *** Error Report *** Version: 4.2.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.47 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.LiveTV.EmbyTV.RecordStream(TimerInfo timer, DateTimeOffset recordingEndDate, ActiveRecordingInfo activeRecordingInfo) Source: Emby.LiveTV TargetSite: Void MoveNext() 2019-08-13 19:44:43.476 Info LiveTV: Triggering refresh on /var/lib/emby/data/livetv/recordings/Vikings/Vikings 2019_08_13_18_14_30.ts 2019-08-13 19:44:43.479 Info LiveTV: Retrying recording in 60 seconds. 2019-08-13 19:44:43.482 Info LiveTV: Creating recording timer for cdf65fa33e484eef8d25495ae4b31ac8, Vikings. Timer will fire in 0.999943501666667 minutes 2019-08-13 19:44:43.482 Info LiveTvManager: New recording scheduled I´ve changed the recording folder to something else but it seems that the folder is not the problem. user rights are also setup and even with emby´s standard folder it won´t work. Anybody experiencing the same problem? Ubuntu 18.04 up to date. Advanced Micro Devices, Inc. [AMD/ATI] Polaris 22 [Radeon RX Vega M GH] (rev c0) Intel® Core i7-8809G CPU @ 3.10GHz Thanks! Edited August 13, 2019 by Sw4rl3y
Luke 42246 Posted August 13, 2019 Posted August 13, 2019 Hi there, please attach the complete emby server log. thanks.
