Ahmed4Subs 1 Posted August 13, 2019 Posted August 13, 2019 (edited) Hi, It would be nice to have an option for single or multi languages metadata fetching. And based on the user settings it display the language metadata with in the home and in libraries. And maybe with a button or dropdown menu like in Audio and Subtitles if there is more than one inside the main page of the media. Thank you. Edited August 13, 2019 by Ahmed4Subs 1
Luke 42246 Posted August 13, 2019 Posted August 13, 2019 Hi, yes I think there's an open feature request for this already. Thanks. 1
Solution neik 874 Posted August 13, 2019 Solution Posted August 13, 2019 Yes, there is: https://emby.media/community/index.php?/topic/70964-multiple-metadata-languages/ 3
Ahmed4Subs 1 Posted August 13, 2019 Author Posted August 13, 2019 Hi, yes I think there's an open feature request for this already. Thanks. I apologize for the duplication! I’ve searched by typing “metadata” in this forum. However, when I didn’t find a title that indicates what I want in the first page, I opened a new thread. Yes, there is: https://emby.media/community/index.php?/topic/70964-multiple-metadata-languages/ Thank you for the link! I’ve read all the replies and I think that the workaround solution by making two libraries with different metadata is a good as a temporary solution. So @@Luke I read your reply here. https://emby.media/community/index.php?/topic/70964-multiple-metadata-languages/&do=findComment&comment=753252 Since that reply, what have you decided?
Luke 42246 Posted August 13, 2019 Posted August 13, 2019 Nothing has been decided. We're continuing to monitor it for community feedback relative to other requests. Thanks ! 1
moviepalace4K 30 Posted October 12, 2021 Posted October 12, 2021 The Easiest tweak in the software I think would be to have the ability to set the location (metadata path) per library to store the metadata. (So: a separate folder per Library; now the possibility is limited to set only 1 folder in the "Advanced" section of the "Library" settings of the server
Luke 42246 Posted October 12, 2021 Posted October 12, 2021 5 hours ago, streamz4k said: The Easiest tweak in the software I think would be to have the ability to set the location (metadata path) per library to store the metadata. (So: a separate folder per Library; now the possibility is limited to set only 1 folder in the "Advanced" section of the "Library" settings of the server That would not result in adding multi language support as this user is asking for.
moviepalace4K 30 Posted October 12, 2021 Posted October 12, 2021 Do I not understand his question? He asks to be able to create 2 libraries from 1 video folder? 1 library of Arabic metadata and 1 library of English metadata? Correct me if I'm wrong
moviepalace4K 30 Posted October 12, 2021 Posted October 12, 2021 (edited) EXAMPLE [MAP] 4K Movies [MAP] 4K Arabic Metadata [MAP] 4K Dutch Metadata [MAP] 4K English Metadata Small example: Library Arabic Metadata scans "4K Movies" and places the metadata in folder "4K Arabic Metadata"; Library Dutch Metadata scans "4K Movies" and places the metadata in folder "4K Dutch Metadata"; Libary English Metadata scans "4K Movies" and puts the metadata in folder "4K English Metadata"; etc... Edited October 12, 2021 by streamz4k
Luke 42246 Posted October 13, 2021 Posted October 13, 2021 Quote He asks to be able to create 2 libraries from 1 video folder? The emby server database will still only have one copy, so that would have to be restructured first.
