rbjtech 5344 Posted May 28, 2024 Posted May 28, 2024 14 minutes ago, next_level said: I can assure the Zidoo is superior, so much so I tick the external player box which stuffs up watched status accuracy but gives the very best video and picture hands down. Good to know - thanks ! Lets keep our fingers crossed it gets native Emby support - that would be a AV Enthusiast's dream
ebr 16336 Posted May 28, 2024 Posted May 28, 2024 On 5/25/2024 at 10:38 PM, flipmode said: the audio seems to be better too With bitstreamed audio I don't see how that can be anything but a placebo effect. 1
flipmode 3 Posted June 11, 2024 Posted June 11, 2024 On 5/28/2024 at 7:52 AM, rbjtech said: If emby every did have native support, then I'd certainly be interested in buying the Zidoo hardware. Personally I think the Shield Pro pic quality is extremly good, on a Remux of a UHD at any rate. HD Audio passthrough is a Shield Pro strength - a bitstream is a bitstream, Zidoo is not going to add anything here - it's the AVR that does the decoding. The Shield Pro supports all BL & MEL DV profiles (5,7,8) and HDR10 just fine - it's HDR10+ that is missing. If the Zidoo could read the full DV (FEL) then it would be the perfect device. The video and picture quality of even the 1st gen HDR Zidoo absolutly obliterates the latest Shield in both aspects. Tone mapping alone makes a difference. I have an old X10 and a new shield and i gave the shield to a friend becuase it was unbearably lower PQ, and that was on 1080p projector. On my Q82 its even more dramatic difference. Nvidia is just a giant corp that pushes sub par hardware using its native android tv support to sell. That's genuine hands on feedback. Also the shield COMPRESSES the LFE channel and there is no work around, its part of their locked version of Android TV. 1
flipmode 3 Posted June 11, 2024 Posted June 11, 2024 On 5/28/2024 at 9:07 AM, ebr said: With bitstreamed audio I don't see how that can be anything but a placebo effect. its not, I measured it, so its not just the ears...i am an audio engineer and have the tools. there is definatly compression in the LFE and SNR is really really bad on the Shield. it's an issue with the API used by the Android TV OS that Nvidia uses. it allows bitstream data to be presented with an AVR, but its not lossless, i believe it is decoded then reencoded back to the hdmi. i can hear it clear as day
rbjtech 5344 Posted June 12, 2024 Posted June 12, 2024 15 hours ago, flipmode said: The video and picture quality of even the 1st gen HDR Zidoo absolutly obliterates the latest Shield in both aspects. Tone mapping alone makes a difference. I have an old X10 and a new shield and i gave the shield to a friend becuase it was unbearably lower PQ, and that was on 1080p projector. On my Q82 its even more dramatic difference. Nvidia is just a giant corp that pushes sub par hardware using its native android tv support to sell. That's genuine hands on feedback. Also the shield COMPRESSES the LFE channel and there is no work around, its part of their locked version of Android TV. Thanks for your insights. tbh, I think the Shield PQ is extremly good on my OLED, BUT I have nothing to compare it against - and some of the differences may be the LG OLED image processing etc. I'm totally happy to take the plunge with a new device if there really is that much of a difference - and considering the Shield 2019 is now 5 years old, I'd imagine the latest video processors have indeed improved - but what i don't want to do, is gain in lets say image quality, but lose in compatibility - for me, the 'it just works' has a lot going for it. 1
flipmode 3 Posted June 18, 2024 Posted June 18, 2024 On 6/12/2024 at 9:03 AM, rbjtech said: Thanks for your insights. tbh, I think the Shield PQ is extremly good on my OLED, BUT I have nothing to compare it against - and some of the differences may be the LG OLED image processing etc. I'm totally happy to take the plunge with a new device if there really is that much of a difference - and considering the Shield 2019 is now 5 years old, I'd imagine the latest video processors have indeed improved - but what i don't want to do, is gain in lets say image quality, but lose in compatibility - for me, the 'it just works' has a lot going for it. totally respectable approach. Your TV image processing no doubt has a major role. I have a Samsung Q82 and it is no slouch, but the differences may be negligable for some. For me its quite dramatic. But where the massive difference is on Projectors. They have a much larger colour palate and the Shield does not send correct colour mapping. Blacks often have 16 bit like texture. Go to a HTPC that supports HEVC hardware decoding and the tone mapping is just outstanding. A mini PC with Emby Desktop might be more in the "it just works" category TBH. Zidoo takes the cake though because it natively supports 3D and I realize that is kinda a Projector custom cinema demograph now. (yes all the new movies still come in 3D lol). But I have to say I am excited to see what the Emby team comes up with, both companies are outstanding. Also it is rumored that Nvida is no longer supporting the Shield so the apps will only be serviced by the vendors, and I think we are all stuck on Android 11 it seems, wich misses the refresh rate switching version 12 fixes. Yes the setting is there but it mismatches most of the time. 1
Hans_Meiser 5 Posted March 8, 2025 Posted March 8, 2025 On 4/3/2024 at 12:30 AM, Luke said: Hi, we have some changes in mind, but haven't done the work yet. Until then you can use the external player feature to open videos using the zidoo player. Hi Luke, any Update in the Zidoo integration? 1
Luke 42243 Posted March 8, 2025 Posted March 8, 2025 2 hours ago, Hans_Meiser said: Hi Luke, any Update in the Zidoo integration? Hi, what exactly are you looking for? Users have reported that many of the previously reported issues have been solved with the latest zidoo updates.
