Luke 42252 Posted July 12, 2014 Posted July 12, 2014 we're doing our best to get them to work with MBC. Unfortunately WMC is a 10 yr old player and doesn't really handle on the fly transcoding very well.
Luke 42252 Posted July 12, 2014 Posted July 12, 2014 they work great in all other clients that support them. In MBC, it is a work in progress and we improving it with each release.
jordy 284 Posted July 13, 2014 Posted July 13, 2014 @@snazy2000, just updated MBS to the latest beta 3.0.5306.42925. Uninstalled vimeo removed the .xml from the plugins\configuration folder to make sure of a fresh start. Re-installed vimeo, set the access password and.... still the same. Cannot play any videos in the Vimeo plugin. Any other ideas?
snazy2000 345 Posted July 13, 2014 Posted July 13, 2014 Im looking in to it. I think vimeo may have changed there website so the plugin may need re making :/
snazy2000 345 Posted July 13, 2014 Posted July 13, 2014 Ive uploaded a new version (1.0.5307.16089) 1
jordy 284 Posted July 13, 2014 Posted July 13, 2014 well done @@snazy2000. It's all good now. cheers :) 1
ebr 16342 Posted July 13, 2014 Posted July 13, 2014 snazy - are you web scraping to get this or using an API?
snazy2000 345 Posted July 13, 2014 Posted July 13, 2014 I'm using the api but the api doesn't return the video file so have to do fetch that from a different url which seemed to have changed. Sent from my HTC One using Tapatalk
Redshirt 1487 Posted September 6, 2014 Posted September 6, 2014 @snazzy2000 Are personal channels working for you in vimeo?
Redshirt 1487 Posted November 26, 2015 Posted November 26, 2015 I think this plugin needs an update to work with current server builds. Running a video through the PlaybackManager now produces a NoCompatibleStream error. it was working a few weeks ago and it's been a while since the plugin was updated. I had a quick look at the plugin source and it looks like MediaSources aren't being created when the videos are initially scraped..
Luke 42252 Posted November 26, 2015 Posted November 26, 2015 Actually this is because some vimeo videos can't be embedded with the public api key but unfortunately we don't find that out until play time when we query vimeo for the actual video URLs. What you see while browsing is just the metadata and at that point we don't have that information. The error message isn't great but that's a side effect of trying to normalize ask these different sources
Redshirt 1487 Posted November 27, 2015 Posted November 27, 2015 That's disappointing. It's unfortunate that it's out of Emby's control because it's almost all videos (that I've tested) that won't play. Maybe the plugin should be nuked until things change. Thanks for looking regardless.
