Modify Library Settings Page - View
PenkethBoy
If you have a lot of Libraries the default view in the Library Settings Page auto adjusts up to 6 columns - so if you want more libraries visible then you need to override the default behaviour
Add the following to your Dashboard>Settings>custom css
/* ----- Adjust Library Settings Page Card Size ----- */
#mediaLibraryPage .backdropCard-scalable {width:10%;}
/*---- wrap card text - long movie names etc ----*/
div.cardText {white-space: pre-wrap;}
The first allows you to change the width of each library "card" - so 10% gets you 10 columns of libraries per page
The second allows the text below the Library Image to wrap so its still readable - warning this applies across the whole web app not just the Library Settings page
Before css applied
After Css applied
Adjust the width to your liking :)
  • Like 1
@PenkethBoy
What is the theme that you are using? Looks nice.
PenkethBoy
theme - dark and dark for the dashboard
BUT - my setup has a lot of css modifications as well
so its a long way from standard
