unisoft 355 Posted August 10, 2019 Posted August 10, 2019 (edited) My HD Homerun 4 tuner device MODEL: HDHR5-4DT always used to work fine but various updates in past few weeks to various Emby apps. Firmware is latest: 20190621 Emby Server version: 4.2.1.0 Here is what I am getting now: 1. On some MPEG2 (SD) TV channels, getting "No compatible streams available" in Emby Theatre and Web app. Other MPEG2 channels (SD) that do display are transcoded when previously they would be shown "direct". The settings are on AUTO. An example TV channel was "DRAMA" which is DVB-T and SD MPEG2. Other DVB-T MPEG2 channels were shown albeit with transcoding. On ROKU, channels display Ok (HD and SD) and not transcoded BUT the channel that says no compatible streams (DRAMA) says "HTTP Error may be malformed request/header" on the ROKU.On android mobile Emby app, I get a spinning wheel when an affected channel is shown like DRAMA 2. LG App 1.17 just displays black screen on affected channel DRAMA 3. HD Channels using MPEG4 are recording content to Synology Server, but Emby Theatre + web client shows spinning wheel. ROKU, LG app and Android are fine and "direct". Nothing strange about Synology DS2415+ NAS server in terms of "fiddling". Standard Emby installation. No errors on any upgrades applied either OS or Emby. This was working and in DIRECT mode without transcode for LG App and Emby Theatre. Android Mobile Emby app IS using "Direct" on SD and HD channels, but is affected on some channels like DRAMA by the no compatible stream (just masked as a spinning wheel). I have done a retune of HD HomeRun (signal is 100% and quality) and done a Refresh Guide data task. Using Emby TV guide data. With exception of the Android Mobile Emby app and ROKU, all the others apps are on wired CAT7 cables to NAS. the HD Homerun app shows ALL channels (whether wired on PC, or WIFI from Android HD Homerun App). Here is an example of output in one of the Transcode logs: http://servername:8096/emby/videos/130560/live.m3u8?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY0LjAuMzI4Mi4xNDAgU2FmYXJpLzUzNy4zNiBFZGdlLzE4LjE3NzYzfDE1NTI4MjAwOTA5MTE1&MediaSourceId=native_7ce9fd452946804bf450f723a11f06ea_9ff54b38d97b2330ff869fc5546747ae&PlaySessionId=a9aeeadbf7784288abeff0df1e0dfcdc&api_key=6ca539d8b7fd4467b8ee2947960a77f4&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_7ce9fd452946804bf450f723a11f06ea_9ff54b38d97b2330ff869fc5546747ae&VideoCodec=h264&AudioCodec=ac3,eac3,mp3,aac,opus&VideoBitrate=139808000&AudioBitrate=192000&AudioStreamIndex=-1&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&TranscodeReasons=ContainerNotSupported {"Protocol":"Http","Id":"native_7ce9fd452946804bf450f723a11f06ea_9ff54b38d97b2330ff869fc5546747ae","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/b2f3d879266c416690dcb1ffeb0da98e/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_7ce9fd452946804bf450f723a11f06ea_9ff54b38d97b2330ff869fc5546747ae","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/90000","CodecTimeBase":"1/50","VideoRange":"SDR","DisplayTitle":"1080pH264","NalLengthSize":"0","IsInterlaced":false,"BitRate":20000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac_latm","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"AAC_LATM stereo","IsInterlaced":false,"ChannelLayout":"stereo","Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0}],"Formats":[],"Bitrate":20000000,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} User policy for USER1: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -analyzeduration 3000000 -fflags +discardcorruptts+fillwallclockdts -f mpegts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/b2f3d879266c416690dcb1ffeb0da98e/stream.ts"-map_metadata -1 -map_chapters -1 -threads 0 -sn -c:v:0 copy -vsync -1 -codec:a:0 libmp3lame -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_entry_prefix "hls/3e4f782351969ff92133d02dd69afe5d/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/volume1/Emby/Transcode/transcoding-temp/3e4f782351969ff92133d02dd69afe5d.m3u8" -y "/volume1/Emby/Transcode/transcoding-temp/3e4f782351969ff92133d02dd69afe5d%d.ts" ffmpeg version 4.0.3-emby_2019_04_09-20190419T192952UTC Copyright © 2000-2018 the FFmpeg developers and softworkz for Emby LLC built with gcc 7.3.0 (GCC)Local Time: 15:07:26T=0.001sT=0.011s[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] SPS unavailable in decode_picture_timing[h264 @ 0xb97240] non-existing PPS 0 referenced[h264 @ 0xb97240] decode_slice_header error[h264 @ 0xb97240] no frame![h264 @ 0xb97240] mmco: unref short failure[h264 @ 0xb97240] Increasing reorder buffer to 3[mpegts @ 0xb76000] Could not find codec parameters for stream 2 (Unknown: none ([17][0][0][0] / 0x0011)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 0xb76000] Could not find codec parameters for stream 4 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 0xb76000] Could not find codec parameters for stream 5 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 0xb76000] Could not find codec parameters for stream 6 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 0xb76000] Could not find codec parameters for stream 7 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/b2f3d879266c416690dcb1ffeb0da98e/stream.ts': Duration: N/A, start: 60975.149522, bitrate: N/A Program 17540 Stream #0:0[0x19c9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], Level 40, 25 fps, 25 tbr, 90k tbn, 50 tbc, Start-Time 60975.945s Stream #0:1[0x19ca](eng): Audio: aac_latm (LC) ([17][0][0][0] / 0x0011), 48000 Hz, 5.1, fltp, Start-Time 60975.150s Stream #0:2[0x19ce](eng): Unknown: none ([17][0][0][0] / 0x0011) (visual impaired) (dependent) Stream #0:3[0x19cd](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006), Start-Time 60977.195s Stream #0:4[0x1c86]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:5[0x1c97]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:6[0x1bc4]: Unknown: none ([5][0][0][0] / 0x0005) Stream #0:7[0x1bc6]: Unknown: none ([5][0][0][0] / 0x0005)T=0.541s Last message repeated 3 timesStream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (aac_latm (native) -> mp3 (libmp3lame))T=0.541sPress [q] to stop, [?] for help[segment @ 0xb7ecc0] Opening '/volume1/Emby/Transcode/transcoding-temp/3e4f782351969ff92133d02dd69afe5d0.ts.tmp' for writingOutput #0, segment, to '/volume1/Emby/Transcode/transcoding-temp/3e4f782351969ff92133d02dd69afe5d%d.ts': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, Level 40, 25 fps, 25 tbr, 90k tbn, 25 tbc Stream #0:1: Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: encoder : Lavc58.18.100 libmp3lame[segment @ 0xb7ecc0] Opening '/volume1/Emby/Transcode/transcoding-temp/3e4f782351969ff92133d02dd69afe5d.m3u8.tmp' for writing Edited August 10, 2019 by unisoft
Luke 42245 Posted August 10, 2019 Posted August 10, 2019 Hi there, please attach the complete emby server and ffmpeg log. thanks.
unisoft 355 Posted August 10, 2019 Author Posted August 10, 2019 Hi there, please attach the complete emby server and ffmpeg log. thanks. OK first off, here are the logs for when I play the DRAMA channel, which is MPEG2 and DVB-T. This is in Emby Theatre App and I get the "No compatible streams" dialogue, even though other MPEG2 SD DVB-T channels play (albeit insisting on transcoding instead of DIRECT) embyserver.txt ffmpeg-transcode-feacf266-416b-4d72-8c8d-9c24fa839295_1.txt
unisoft 355 Posted August 10, 2019 Author Posted August 10, 2019 (edited) Here is the DRAMA channel played in the web client which also gives the "No compatible Streams" dialogue. ffmpeg-transcode-07dbf30c-448a-4312-91fd-0c480c5f3332_1.txt ffmpeg-transcode-81035fd2-dc27-42b0-8e1e-84bf3eb31f7b_1.txt ffmpeg-transcode-d3c77b8b-85a4-4b44-8f45-c4b9995c978e_1.txt embyserver.txt Edited August 10, 2019 by unisoft
unisoft 355 Posted August 10, 2019 Author Posted August 10, 2019 (edited) and here is the log when I try to play BBC1 HD in Emby Theatre where I just get a spinning wheel of death, but it direct plays in ROKU, Android Mobile App and LG App. embyserver.txt ffmpeg-remux-8a1d3d8b-b6df-4733-bac9-8cb76bed1080_1.txt Edited August 10, 2019 by unisoft
Luke 42245 Posted August 10, 2019 Posted August 10, 2019 This is an HDHR model that has the dlna features, right?
unisoft 355 Posted August 10, 2019 Author Posted August 10, 2019 (edited) This is an HDHR model that has the dlna features, right? Yes it has dlna but don't use that in Emby. Edited August 10, 2019 by unisoft
