e123enitan 276 Posted August 8, 2019 Posted August 8, 2019 (edited) Hi Appreciate if someone could point me to the right direction, I just added few music to by server, the issue that I have are the artist profile, artwork and etc did not download. I have last.fm plugin installed, I endure in the library setting I enabled last.fm metadata and art, yet nothing seems to be populating. Any suggestions; Server 4.2.0.40 File arrangement Music Folder >Artist Folder >Album folder Edited August 8, 2019 by e123enitan
chacawaca 109 Posted August 8, 2019 Posted August 8, 2019 Probably same thing as this https://emby.media/community/index.php?/topic/75658-lastfm-seem-to-dont-work-with-artist-picture/ albums work but artists doesn't.
Luke 42219 Posted August 8, 2019 Posted August 8, 2019 Probably same thing as this https://emby.media/community/index.php?/topic/75658-lastfm-seem-to-dont-work-with-artist-picture/ albums work but artists doesn't. They work just fine. It depends on what images are available from the available image providers.
Luke 42219 Posted August 8, 2019 Posted August 8, 2019 Hi Appreciate if someone could point me to the right direction, I just added few music to by server, the issue that I have are the artist profile, artwork and etc did not download. I have last.fm plugin installed, I endure in the library setting I enabled last.fm metadata and art, yet nothing seems to be populating. Any suggestions; Server 4.2.0.40 File arrangement Music Folder >Artist Folder >Album folder Hi there, please discuss an example and attach the information requested in how to report a problem. thanks !
e123enitan 276 Posted August 8, 2019 Author Posted August 8, 2019 Hi Luke, I checked MusicBrainz and Last.fm the image artist there, what specific info do you need. Thanks
Luke 42219 Posted August 8, 2019 Posted August 8, 2019 The information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
e123enitan 276 Posted August 8, 2019 Author Posted August 8, 2019 I will grab log file and screenshot for your review.
chacawaca 109 Posted August 8, 2019 Posted August 8, 2019 (edited) They work just fine. It depends on what images are available from the available image providers.He mentioned last.fm and this provider doesn’t work at this moment for artists. But it work for album. Edited August 8, 2019 by chacawaca
Luke 42219 Posted August 8, 2019 Posted August 8, 2019 I will grab log file and screenshot for your review. Thanks !
e123enitan 276 Posted August 9, 2019 Author Posted August 9, 2019 I will grab log file and screenshot for your review. Hi Luke attached is server log, I a not sure need to change in term of music settings,I did turned the server off/on then refreshed the music library yet nothing shows embyserver.txt Those are my music library settings \\NAS27ADDF\Public\Music Library SettingsPreferred metadata download language: Country: Preferred image download language: Enable real time monitoring Changes to files will be processed immediately, on supported file systems. MusicAlbum metadata downloaders: last.fm Enable and rank your preferred metadata downloaders in order of priority. Lower priority downloaders will only be used to fill in missing information. MusicArtist metadata downloaders: last.fm Enable and rank your preferred metadata downloaders in order of priority. Lower priority downloaders will only be used to fill in missing information. MusicVideo metadata downloaders: IMVDb TheMovieDb Enable and rank your preferred metadata downloaders in order of priority. Lower priority downloaders will only be used to fill in missing information. Automatically refresh metadata from the internet: Enabling this option may result in significantly longer library scans. Metadata savers: Nfo Choose the file formats to save your metadata to. MusicAlbum Image Fetchers last.fm FanArt Enable and rank your preferred image fetchers in order of priority. MusicArtist Image Fetchers last.fm FanArt Enable and rank your preferred image fetchers in order of priority. Audio Image Fetchers Image Extractor Enable and rank your preferred image fetchers in order of priority. MusicVideo Image Fetchers TheMovieDb FanArt Screen Grabber Enable and rank your preferred image fetchers in order of priority. Save artwork into media folders Saving artwork into media folders will put them in a place where they can be easily edited. Download images in advance By default, most images are only downloaded when requested by an Emby app. Enable this option to download all images in advance, as new media is imported. This may cause significantly longer library scans.
Luke 42219 Posted August 10, 2019 Posted August 10, 2019 Does the artist have a musicbrainz id assigned?
Luke 42219 Posted August 10, 2019 Posted August 10, 2019 In many cases we're not going to be able to get an image from lastfm anymore for this reason: https://emby.media/community/index.php?/topic/75658-lastfm-seem-to-dont-work-with-artist-picture/?p=766507 The artist needs to have a musicbrainz id assigned and then we can use that id to check for images on fanart, musicbrainz and audiodb, if you have those image fetchers enabled.
Luke 42219 Posted August 10, 2019 Posted August 10, 2019 And it looks like you uninstalled the musicbrainz plugin, that means the server cannot lookup the musicbrainz id for you. This means you need to manually enter it for each artist, then try refreshing the metadata on the artist after entering it.
chacawaca 109 Posted August 10, 2019 Posted August 10, 2019 In many cases we're not going to be able to get an image from lastfm anymore for this reason: https://emby.media/community/index.php?/topic/75658-lastfm-seem-to-dont-work-with-artist-picture/?p=766507 The artist needs to have a musicbrainz id assigned and then we can use that id to check for images on fanart, musicbrainz and audiodb, if you have those image fetchers enabled. musicbrainz have no artist image only album.
Luke 42219 Posted August 10, 2019 Posted August 10, 2019 musicbrainz have no artist image only album. Sorry you're right, my mistake. We can use the musicbrainz id to lookup images on fanart and audiodb.
chacawaca 109 Posted August 10, 2019 Posted August 10, 2019 Do you know other source for artist image @@Luke?, actually on linux with only fanart, that suck.
Luke 42219 Posted August 10, 2019 Posted August 10, 2019 .Net core 3.0 is being released next month so I think Emby Server 4.3 will be able to restore audiodb support.
