simonguillot@yahoo.ca 1 Posted August 7, 2019 Posted August 7, 2019 hi i am starting to feel like a bitch because i have not been able to play any files that is 1080P H264 since the last update please let me know why i paid premium and why should i stick with emby instead of plex i understand you are probably pulling your hair out many times a day , but i feel the same way on my end i did all i could to improve the server, did a reinstall, redone cabling and now server is connected straight to the router uninstalled a few assons please let me know what else am i supposed to do to be able to play this format with no issues thank you log8-7.txt
Luke 42219 Posted August 7, 2019 Posted August 7, 2019 Hi there, can you please try lowering the in-app quality setting and see if this helps? Thanks !
simonguillot@yahoo.ca 1 Posted August 7, 2019 Author Posted August 7, 2019 hi i tried 1080 - 30 mbps = fail 1080 - 20 mbps = fail 1080 - 10 mbps = fail 1080 - 6 mbps = fail 1080 - 4 mbps = fail 720 - 2mbps = fail 720 - 1mbps = fail i am not going to test 480 still having a slow loading time / stuttering / taking a pause every 5 seconds to buffer if i download 1080 it is because i want good quality at home i got 15 mbps upload bandwidth which is pretty much all for this server and only me and an other user connecting usually not even at the same time please let me know of anything else that i could test thanks
simonguillot@yahoo.ca 1 Posted August 7, 2019 Author Posted August 7, 2019 i reverted the player setting back to auto now i am getting a playback error on a file that was working well tabarnak log8-7-v2.txt
Luke 42219 Posted August 8, 2019 Posted August 8, 2019 If you turn off hardware acceleration under the server transcoding settings, does that have any impact?
simonguillot@yahoo.ca 1 Posted August 9, 2019 Author Posted August 9, 2019 turned off transcoding and still getting buffering, slow loading time had latest version upgrade last night, no changes watching movie is like being back in 2000 where you have to pause for 30 sec and watch 1 minute of movie 08-09.txt
Luke 42219 Posted August 9, 2019 Posted August 9, 2019 Hi, I didn't say turn off transcoding. I said turn off hardware acceleration under the server transcoding settings. What did you do?
simonguillot@yahoo.ca 1 Posted August 9, 2019 Author Posted August 9, 2019 i am pretty sure i turned off the hardware acceleration
simonguillot@yahoo.ca 1 Posted August 9, 2019 Author Posted August 9, 2019 i just tried to switch from NVDEC to DX11VA in the decoders ...because .. you never know ... to see that quality in DX11 almost gave me an headache :-D
simonguillot@yahoo.ca 1 Posted August 11, 2019 Author Posted August 11, 2019 hi could this be related in the fact that i am remotely streaming using a web browser ? and if so, what am i supposed to di in this situation thanks
simonguillot@yahoo.ca 1 Posted August 11, 2019 Author Posted August 11, 2019 i did not know which one of the ffmpeg you want i picked the last one ... also i did not encountered this issue buffering issue today as i was playing all from home, so i am not sure if the log will helpffmpeg.txt
simonguillot@yahoo.ca 1 Posted August 13, 2019 Author Posted August 13, 2019 so, is there any way, i will be able to stream more than 480 P without stuttering / slow loading times ? thanks ffmpg.txt
