hvt 6 Posted August 18, 2019 Author Posted August 18, 2019 Here are the Firefox developer tools network tab events. Maybe they help?
Luke 42246 Posted August 19, 2019 Posted August 19, 2019 What about your previous answer where you thought it was resolved?
hvt 6 Posted August 19, 2019 Author Posted August 19, 2019 I think that this is the best answer. Not correct but right. It helped me. It was resolved fully. The problem is still there but before there was a gray overlay when starting the stream. It wasnt there anymore after activating the reverse proxy. The stream sadly still does not start. Next steps I'll take: Throw away the old and clumsy apache and swap with traefik or nginx. Unfortunaly emby docs do not provide preconfigured files for this. I really cant figure out why this issue exists. It works fast on the same url, same browser, same device, same user, same reverse proxy when accessing it from the outside of the LAN. Currently I am using Emby Theater for streaming as the Web UI is not usable. Other: Looking for possibilities to get into the code/logs to search for bottlenecks more granularly.
Solution hvt 6 Posted January 7, 2020 Author Solution Posted January 7, 2020 For everyone having similar issues. Also @@Justy After setting up a local DNS server and directly pointing the DDNS address to the local ip it works. Before the IP was resolved to the public ip like it does when doing it from the outside world. 2
EatPrilosec 22 Posted June 17, 2021 Posted June 17, 2021 On 1/7/2020 at 5:10 AM, hvt said: For everyone having similar issues. Also @@Justy After setting up a local DNS server and directly pointing the DDNS address to the local ip it works. Before the IP was resolved to the public ip like it does when doing it from the outside world. thanks for the meme and the fix this was messing me up for a day. just added 192.168.1.1 (back) to my advertised DNS list for DHCP lol
Luke 42246 Posted June 21, 2021 Posted June 21, 2021 On 6/16/2021 at 10:12 PM, NErdgOd56 said: thanks for the meme and the fix this was messing me up for a day. just added 192.168.1.1 (back) to my advertised DNS list for DHCP lol Thanks for the feedback.
