vdatanet 1619 Posted August 14, 2019 Author Posted August 14, 2019 I found this one : https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/306742/worse-wifi-performance-since-pie-update/ Yes, I've seen that. I was talking about the issues posted in the main topic (https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/305571/shield-experience-upgrade-80/) The wheel of my mouse draws smoke.
BillOatman 597 Posted August 14, 2019 Posted August 14, 2019 - VC1 playback not working. That will make some people here happy though!
Spaceboy 2573 Posted August 16, 2019 Posted August 16, 2019 Having issues using UniFi AP. I have the long range version. Can’t / don’t really want to disable 2.4 as other devices need it.
kikinjo 294 Posted September 5, 2019 Posted September 5, 2019 I had a awful time with 8.0, my LG OLED TV started loosing signal over hdmi, no fix for it also, nvidia is aware, it also happens on Samsung tvs, also had some other minor issues, but got sick of it and flashed old 7.2.3 firmware and got back and now all working fine :-). After successfully getting back i killed the 8.0 update nag and now no issues whatsoever and no more update to 8.0 crap.
Spaceboy 2573 Posted September 5, 2019 Posted September 5, 2019 I bought a cheap travel router and using that as a wireless client to which my shield is connected
vdatanet 1619 Posted September 7, 2019 Author Posted September 7, 2019 (edited) Those who have wifi problems test last hotfix: .... The list of new items resolved in the third HotFix (32.5.205.63): - Wifi throughput issues causing 4k streaming, etc issues - Some controllers joysticks ... https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/305747/shield-experience-upgrade-80-hotfix-image/ Edited September 7, 2019 by vdatanet
Solution Flibi 2 Posted September 7, 2019 Solution Posted September 7, 2019 Those who have wifi problems test last hotfix: .... The list of new items resolved in the third HotFix (32.5.205.63): - Wifi throughput issues causing 4k streaming, etc issues - Some controllers joysticks ... https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/305747/shield-experience-upgrade-80-hotfix-image/ The new update solved the issue for me. 1
