z3ndra 7 Posted August 5, 2019 Posted August 5, 2019 (edited) hello,I realized that when we try to connect to his account locally (not with emby connect), while a vpn is activated, the connection is impossible. do you know why ? it's annoying because it shows that the identifiers are incorrect while it's just the vpn blocking, I do not understand. it is quite compelling when a user forgets to disable his vpn when it should not block thank you in advance Edited August 5, 2019 by z3ndra
Luke 42242 Posted August 5, 2019 Posted August 5, 2019 Hi, it sounds like the VPN is blocking the traffic and will need to be configured to allow it, right?
