Edgared 8 Posted August 4, 2019 Posted August 4, 2019 Hello Every Kodi startup I am asked to connect with Emby connect or manually to the server and then to connect to my account. on all my devices under Kodi and with all the accounts. other devices with Emby application native no problem. Do you have a solution ? Thank you
Angelblue05 4132 Posted August 4, 2019 Posted August 4, 2019 Provide your Kodi log. That is not normal.
Edgared 8 Posted August 4, 2019 Author Posted August 4, 2019 (edited) thank-you for your prompt response Edited August 5, 2019 by Edgared 1
Angelblue05 4132 Posted August 4, 2019 Posted August 4, 2019 thank-you for your prompt response I am looking into it, I’ll keep you updated.
Angelblue05 4132 Posted August 5, 2019 Posted August 5, 2019 (edited) @@Edgared Can you install this build over the current one. You may need to select the server/enter your credentials one more time. Does the issue persists upon restarting Kodi? plugin.video.emby-4.1.12c.zip Edited August 5, 2019 by Angelblue05
Edgared 8 Posted August 5, 2019 Author Posted August 5, 2019 Hello yes the problem still persists when starting Kodi after installation of this build. thank you 1
Angelblue05 4132 Posted August 5, 2019 Posted August 5, 2019 (edited) @@Edgared Are you able to open the following file, in Kodi user profiles/userdata/addon_data/plugin.video.emby/data.json open in a file editor. Do you have other servers listed before the server you are trying to connect to? Edited August 5, 2019 by Angelblue05
Angelblue05 4132 Posted August 6, 2019 Posted August 6, 2019 @@Edgared I cannot replicate this here, do you have special characters maybe in your username or server name?
Edgared 8 Posted August 6, 2019 Author Posted August 6, 2019 Hello I have no special characters neither in the username nor in the server name just uppercase, lowercase and numbers. it's been over 2 years that all worked properly, I feel that this problem and appeared with the 4.2.0.40 server update but I'm not sure. I did not have much free time it is last day but I will do other tests and check all users and devices concerned and start from zero (kodi and addon emby) in order to be the most accurate possible. Thanks 1
Solution Edgared 8 Posted August 7, 2019 Author Solution Posted August 7, 2019 Hey, after resetting Kodi and the addon I still had the same problem. I created a new user and set manually connected and it worked fine. I then delete my account Emby connect from my user and I connect manually and everything worked fine then I have again associated my account Emby Connect reconnect via Emby Connect and everything seems to work properly. I tried local reboots of the database Kodi reboots and the server all seems stable. I have the impression that there was a problem with Emby Connect. 1
Edgared 8 Posted August 9, 2019 Author Posted August 9, 2019 Everything seems stable now. Thank you very much for your involvement and your responsiveness. 1
